What to check before buying new Tipm module
Every time I get a p0882. I replace the tipm. The tipm isn't sending power to the TCM. So the TCM isn't powering the solenoid pack. Don' try bypassing or powering up the wires, tried that, didn't work. I work on auction cars also and that many people tried to bypass. Replaced about a dozen this year.
Codes refer to transmission control module problems === causes wiring --poor connections ---short to ground -- wiring short to positive - TCM
check the condition of the wires at the box and the connections for loose, water and corrosion , then replace the TCM unit
On
these issue, there are few solved help links for troubleshooting the
issue easily.-------
Click
the link below: ---
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction
control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light
flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These
details will help.
Thanks.
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
these issue,there are few solved help links for troubleshooting the
Click
the link below:---
No 4x4 light on dash?
4X4 Truck makes roaring
noise in the front end?
Car will not go into 4WD
high or 4WD low?
4 wheel drive system will not disengage?
4WD light is flashing and
beeping? NO 4WD high?
2002 Jeep Wrangler: 4WD Idiot Light is ON?
Traction
4WD light
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
4x4 front differential will not engage the
axle on ford?
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4
light keeps flashing
4X4 LOW LIGHT
IS FLASHING ON DASH
Ford 4x4 front wheels will not engage?
These
details will help.
Thanks.
so you dont think replacing tipm will correct problem,just replsce tcm module?
Thanks I'll try replacing tipm
