Question about Refrigerators
Refrigerator not keeping cold. Shut off and starts and gets cold then stops. Rear drain tube clear, rear fan clear and operating. No pet hair clogging rear. Understand 1 or 2 more fans and several boards inside. Led lights on front fridge come and go off. so, hired so called Samsung certified repairman. He said it was a board and replaced it. Worked for 1 day then stopped cooling again. Called him back and brought friend with him who he claimed had a Samsung diagonostic meter to determine what was acually wrong and which board was out this time, if any. All he had when out the second time was an o meter, which anyone knows how to use. Now repairman, whom we paid nearly $250 to says its the fan not blowing inside freezer air from the bottom freezer to the upper food compartment. I have been without a fridgertor since July 2, 2009. Repairman left no loaner. Said had ordered fan from Samsung and still waiting for Fan to come in. Been 10 days or more. Didn't offer to call samsung again and said when fan comes in will call me. Appears something not right. I dont think samsung sells parts directly, so think hes is lieing to me. Also, the board he took out has a test switch/button and he had no electric meter and he never reset the test button, so I am thinking he is incompetent and doesn't know what he is doing and certainly not Samsung Certified. So How do I fix this fridgerator? What should I do. On fixed income, he cashed my check 3 weeks ago and doesn't seem particualy concerned. Help! I think he replaced a board as follows: #DA41-00128D, a PBA Main/Main PCP . My price on internet is $53.71 plus $7 shipping, so made pretty good money off of me and my wife. Our address is 6408 Lago Vista Dr Fort Worth, Tx 76132 and ph# 817 689 0383 cell. Ask for Jim. Any real Samsung Techs close by that know what they are doing? Hi
  • jakcpa4 Jul 18, 2009
    You are saying the same thing the present repairman has said, that the fan in not working in the freezer?, which I would think from what you said, starts blowing when receives signal from main pc board that freezer has reached temp say 5 degrees or the temp setting, then the fan kicks on and blows air intermittently to regulate both temps in freezer and food compartment.
    I understand from another tech and from just plain common sense one can check if condensor fan in the freezer is working by holding palm of hand against vents leading from the freezer to the food compartment, that is how I think the present repairman checked 3rd time he was out with his helper that had a o meter, but I wasn't there, so maybe never used the meter. Not too scientific using the hand to determine if problem with fan or with some other part, but if fan keeps running then stopping, seems like problem may not the fan but the temp switch/thermstat as you suggest.
    I dont know anything about the temperature sensor/switch or what you call a condensor fan thermostat, but that seems more likely to be the problem to me as the fan runs when unplugged and plugged in again, reaches operating temps, then gets warm again and stops blowing.
    I dont think a fan would run then overheat, then run again, so the temp sensor/switch,thermostat would seem most likely to be the problem, and maybe didnt even need tor replace the main PCB board.
    Is there a shut off switch on the fan if the fan overheats?
    I understand that there is a safety shut off switch on the compressor when it over heats, that makes sense, since very expensive to replace a compressor and runs warm anyways, and would cost way too much to replace. I know on A/C units have safety/reset switch and on cars too, when free-on too low or pressure gets to high (blockage or overcharged, or evaporator or condesor clogged).
    Where is the temp switch/thermostat located, how to get to it? How can this be checked, with a meter, just in case the repairman doesn't know? . I will take your advice and advise the repairman to check out the temp control that sends a signal to the main board that in turn sends a signal to the condenor fan in the freezer section when to start and when to stop to regulate the freezer and food compartment temperatures according to the settings!
    I hope Im saying all this the right way. I just dont want the repairman to come out a 5th or 6th time and take another 2-3 weeks to fix without a backup fridge.
    Thanks!
  • jakcpa4 Jul 21, 2009
    THE REPAIRMAN STILL HASNT BROUGHT OUT A REPLACEMENT CONDENSOR FAN THAT HE ALLEGED IS OUT ALSO, AFTER HE ALLEGED THE BOARD WAS OUT AND CHARGED US FOR A NEW BOARD. SO NOW THAT NOTHING HAD CHANGED, OUT OVER $200 WELL JUST HAVE TO SEE IF THE FAN IS BAD WHENEVER HE SHOWS UP, BEEN 2 WEEKS AGO WHEN HE ORDERED THE FAN. STILL NO FAN HE ALLEGED HE HAS NOT RECEIVED IT FROM SAMSUNG. MAKES US WONDER IF HE IS JUST A PARTS REPLACER AND JUST KEEPS REPLACING AND CHARGING FOR PARTS UNTIL THE PROBLEM IS RESOLVED. WILL LET YOU KNOW WHAT HE SAYS WHEN AND IF HE EVER SHOWS UP AGAIN WITH THE FAN. MY GUESS IS THAT HE NEVER ORDERED THE FAN, IS A USED APPLIANCE SALESMAN/REPAIRMAN, AND HAS LITTLE EXPERIENCE AND NO TRAINING OR TRAINING MANUALS AND DIDNT EVEN OWN A O METER, HAD TO BRING FRIEND OUT WITH ONE A SECOND TIME TO PINPOINT THE FAN AS NOT WORKING. NOTHING CHANGED SINCE HE REPLACED THE BOARD, SO MAKES ONE WONDER IF THE BOARD NEEDEED REPLACING AT ALL AND JUST BEING UP CHARGED FOR MORE PARTS UNTIL HIS BILL GET TO THE $500-$600 RANGE, NEARLY THE PRICE OF THE ENTIRE FRIGERATOR!. WILL KEEP YOU POSTED. THANKS I WILL MENTION THE THEROMOSTAT AS POSSIBLY THE ONLY THING WRONG IF THE UNIT STILL DOES NOT COOL PROPERLY WITH A NEW BOARD AND FAN. WHAT ELSE COULD IT BE? REMEMBER THE UNIT WOULD COOL DOWN, BOTH FREEZER AND FOOD COMPARTMENT THEN NEXT DAY WOULD COOL ANY LONGER WITH SOME Led LIGHTS NOT WORKING. UNPLUG IT FOR 2R HOURS GIVNG ANY ICE THAT BUILT UP TO MELT AND REPLUGGING IN DID THE SAME THING BEFORE AND AFTER THE BOARD REPLACED, SO THINKING MAYBE IS ONLY THEROMSTAT STICKING AND WAS NEVER A NEED TO REPLACE THE BOARD OR THE FAN. WELL SEE. THAN YOU!
  • Refrigerators Master
  • 3,866 Answers
Check the fan in the freezer and see if its on if its not replace the condenser fan and you be all good. This happend to me as well and this is all I had to do. Check the thermstat as well if your fan is working it may be going off to soon.
Thanks
Posted on Jul 18, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jul 18, 2009
    I understnad your fustration the temp switch should be where you select you temp you want. The fan will not overeat whver told you this is ridiculas the motor will go out but overheat oh geez who told you this? If the condenser fan stops without the termistat that means the motor is going out. I am sorry but these type of motors go out not overheat! They would oly overheat if you put the wroung voltage to them even in that it still would spin faster then it should and give out sooner.
    I kind of chuckled at the overheating statment as only a gas motor without water would overheat. A eletric motor would spin faster yes and its magnets would give out sooner YES but overheating no.
    The thermstate is and should be where you select you temp in your unit. Please do accept if you accepted the solution thanks
    Rulds2008
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
Its a Amana AFF2534FEB bottom freezer. The freezer works fine, but the refrigerator does not work. It is only 3yrs old.
Hello; Sorry for the delay in answering, the site did not send me a message telling me that I had a question. My name is Houston and I think I can help you with your problem.
From what you said, it could be several difference things, so you will need to do a little troubleshooting to figure out what it could be. I would start by checking and cleaning the condenser grill that is located under the cabinet next to the compressor. What works best is either a flat brush or an air compressor and shop vacuum. Blowing from the rear and vacuuming from the front. Although this is probably not the problem it will help your unit work more efficiently. If the condenser grill is dirty or has a large accumulation of hair balls or dust bunnies the condenser grill can't get rid of the heat build up of the coolant.
The next thing you need to check is to make sure the fan is operating and blowing the cold air from the freezer into the refrigerator. It is the fan on the inside of the cabinet. You can check it visually and if it is operating then you should then make sure that the cooling tube is allowing that cold air to enter the refrigerator. If you do not feel a positive air flow into refrigerator when the fan in operating that is a sure sign that the tube has a build up of frost and ice. You can defrost the tube by using a hair dryer, blowing down the tube.
If it was not the cooling fan or the cooling tube the last item is the thermostat that is located in the control area of the refrigerator.
ThermistorPART NUMBER: 12002355
Hope this helps and that you are operational with the easy fix.
Houston aka ImJustAvg
Oct 23, 2011 | Amana ARB2217CSR Bottom Freezer...
Freezer vents full of frost.around every two months. Top refrigerator warm up. I resolve by removing all frost and ice from the freezer vents to clear cold path and get it to work. Possible problems...
First try melting the ice with hair dryer. See drain tube going to pan under frig? It can get clogged/frozen with ice. I cleaned mine with very warm water shot out of a water pik. Or u can hair dryer it, then pour warm water on the little pan that holds the drain tube. Be sure that tube is clear for draining.Otherwise, more ice at vents.
Aug 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Refrigerator with top freezer has water leaking into the refrigerator. Both the refrigerator and freezer and still cold.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Feb 19, 2011 | Amana Refrigerators
The bottom of my refrigerator fills with water beneath the storage bins. It is a top freezer model.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line .
Apr 17, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
I have a model ET20GM Whirlpool refrigerator. Whenever the top freezer automatically defrosts, water has started to drip down to the top glass shelf in the refrigerator. This is happening twice a day. ...
Remove the food and icemaker (if it has one) . Remove all the screws holding the rear panel on and remove the rear panel . Using a hair dryer , start in the middle below the coils , and defrost until you see the drain hole . Keep defrosting the hole , sometimes hot water helps , until water starts to go down . Use a small hose inserted into the hole , and blow thru to blow out any debris collected in the drain tube . Get a piece of ALUMINUM wire , stripped of insulation (14-16 guage ) and put as far into the drain hole as it will go without any force . Sometimes bending slightly will help it go farther . Wrap the other end 1 or 2 turns around the black rod ( defrost heater ) above the hole . When refrig goes into defrost , the heater will transfer heat to the aluminum wire , keeping the drain from freezing again . Reinstall the back panel and icemaker ( if equiped ) and the food .
Aug 29, 2009 | Whirlpool Refrigerators
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
Aug 27, 2009 | Refrigerators
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
