Question about Husqvarna Viking 1
I was trying to change the stitch setting on my husqvarna 400 sewing machine, and it seems like the panel does not respond to anything that i touch. the machine does not even go into reverse. Is the control panel locked up or the circuit board gone?
I have this problem with my Viking Lily sewing machine, only when the humidity is fairly high, otherwise it always works perfectly. I don't know why this happens.
Posted on Jul 30, 2009
  • 46 Answers
It could be the touch panel or the main board. The touch panel ribbon connector could be loose but not likely. Needs to be diagnosed by a good tech. for Viking.
Posted on Jul 25, 2009
Singer futura xl-400 machine software is corrupt how do I fix it.
Is this when you're sewing, rather than doing embroidery? If that's the case, you might have a motherboard problem. You should make arrangements to get it serviced.
Aug 14, 2014 | Singer Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
Husqvarna making squeaking noise
try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Dec 08, 2012 | Sewing Machines
My husquavarna lily stitches are too big and won't respond to touch pad
it sounds like the machine needs to be serviced, you have to check
with a sewing machine shop in your area & call them to ask the
price for checking or servicing a sewing machine
Aug 04, 2012 | Husqvarna Sewing Machines
Touch pad on front frozen up
The machine is a "computer" and needs to be repaired by the dealer.
Mar 14, 2010 | Husqvarna Designer I
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
Husqvarna 955E will not change stitch length. Is
Does the length on the display change or is it as if the buttons are not even working. If the touch pad is malfunctioning you will probably find other buttons not working. Try all of the buttons and see if others do not work. If this is the case, the keypad can be replaced.
Sep 02, 2009 | Husqvarna Viking 1
Programming
Hi
Sounds like a screen calibration problem. Will need a dealer to check it and recal if required.
Oct 21, 2007 | Husqvarna Designer I
Sewing Machines Logo
244 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
