Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Which side should face me (black or white) when I put in the CF-1 replacement filter?
  • 14 Answers
The white side is filter media and the black side charcoal. The black side should be the side that the air flows out of and the white the side that the air flows into.
Posted on Sep 11, 2009
How to replace three wire on a Oreck U4180 motor
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/2e7c587.jpg
ck out these wiring diagrams. usually black goes on 1 side where the black dot is and white is piggy backed on the opposite side.
Good Luck
Aug 30, 2015 | Oreck Vacuums
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
DC16 charger output 28VDC Battery 23.6VDC only runs 1-3 sec what is wrong
Hi Rene,
I am sorry to hear that your DC16 handheld seems to have a short runtime.
This issue is generally the result of the filters needing to be washed or not being seated properly in the machine. If the machine is being used regularly, the filters should be washed monthly otherwise it will impact the performance of the machine.
To inspect the filters follow the steps below:
Remove the canister and separate the nozzle from the main body of the machine by pressing the silver button on the top of the machine.
Remove the pre-filter.
There are two portions to the washable pre-filter a blue sponge and a white scrim that has blue plastic.
In the lower right hand corner of the blue plastic is a small silver disc. Opposite of the small silver disc is a hole that should slip onto a molded plastic post in the main body of the machine.
While holding the handle of the machine in your right hand locate and lift up on the small "lip" on the left-hand side of the main body where the vents are.
The rectangular blue sponge is your post motor filter.
These filters should be washed once a month in cold water (no soap) and left to dry at room temperature for 24 hours or more.
If any gray is visible on any part of the filters they need to be washed.
When replacing the pre-filter into the machine it is important that the blue sponge face away from the motor and the small silver disc on the white portion be positioned in the lower corner of the main body.
If the steps above do not fully resolve the problem, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Nov 29, 2012 | Dyson DC16 Root 6 Bagless Handheld...
I just need to know whether the filter is installed with the black side outward or inward facing.
The coarsest side of the filter should be facing the dirty side of the airstream. The dirt / air should pass through the coarse side of the filter before exiting the finer side of the filter.
Hope that helps.
Mar 05, 2011 | Vacuums
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
How do you wire a 2 speed fq motor. I know the blue/blue. the red/red. The yellow /yellow and I believe the whites together with the grey of the pn outlet. Does the black from the motor the black from the...
I have not seen the new two speed but sounds like the wiring is coded to teh switch by colorOn a single speed it would be this way.
Power cord to side 1 of switch.
Switch to motor 1 and PN receptacle 1, etc
Then cord to remaining motor 2 and PN 2 so by color should be accurate.
Note PN receptacle should likely be powered at both speeds....it is on other vacs
Oct 23, 2009 | Filter Queen Cheetah II Ash - MU305...
How do I change the hepafilter on my Rainbow E series? Thanks judyc0293@netscape.net
You have to remove rear cover (on the opposite side than the intake is) There are 2 kinds of HEPA and 2 kinds of filter covers:
HEPA encased in black plastic - on the bottom of the unit you will see two latches and you can use a flat screw driver release them and filter cover just pops out.
HEPA older style (white filter with black plastic frame) - there are 2 Phillips screws on the bottom of the unit and 2 more under the cord caddy. Use flat screw driver to remove the cord caddy (put it in between the housing and the caddy and it would come off)
If you need filters - they are HERE.
Good Luck
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I have a hoover windtunnel bagless that the filter fell out of on accident when I was trying to dump it and I can't figure out how to put it back in
Hi, You don't say which model windtunnel you have but most are the same. The canister is in two sections with a Hoover emblem to the right of the handle. this is the side the filter goes on. The bracket slides out and holds the round filter, the round filter snaps into the bracket so that the end of the filter with the opening goes down to fit the hole in the bottom of the canister. When putting the canister back in the vacuum be sure the top goes back flat on the canister and the locking lever is open all the way. You have to slide the canister back in level and then it will drop down into position you can't tilt it. now you can lock it. Good Luck!
Jan 29, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
163 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
