Question about Casio FX-115ES Scientific Calculator
I need help learning how to input fractions or integers divided by other # here is the problem 12divided by (-3)-(5-3) ________________ -5(2)+4
  • Casio Master
  • 7,993 Answers
The best advice I can give you is to unfold the user manual and start one step at a time . Detailed exemples of each kind of calculation are in the appendix to the user s annual.
Sorry I have no easy way to show you how to input without images.
Good luck
Posted on Sep 12, 2009
Improper fraction to mixed number
You do the operation to get a decimal number.
Isolate the integer part (to the left of the decimal point)
Convert the non integer part (decimal part) into a fraction.
Write the result as (integer part) (fraction part)
3/2=1.5
Integer part is 1, decimal part is 0.5
0.5 as a fraction is 1/2
3/2= 1 1/2
Sep 09, 2014 | Texas Instruments TI-84 Plus Calculator
Decimal to mixed number fraction
3/2=1.5
3/2= 1 1/2
Sep 09, 2014 | Texas Instruments TI-83 Plus Calculator
What is a mixed number or in a fraction in simplest form 0.15%
A mixed number is a number composed of an integer (whole) number and a proper fraction, one that has a numerator less than the denominator. Example 2 1/3 =2+ 1/3. 2 is the integer part, and 1/3 is the proper fraction part.
Certain fractions can be simplified further because the numerator and denominator share a (common) factor. By cancelling the common factor in the numerator with the factor in the denominator,
one gets a fraction with smaller numerator and denominator.
For example the percentage you provide 0.15% can be converted to 15/10000.
Since 15 and 1000 are both multiples of 5, the number 5 is a common factor in both. 15=5*3, and 10000=5*2000
Cancel the two 5 (simplifying by 5) in numerator and denominator leaves 3/2000. Thus
0.15%= 0.15/100=0.0015=3/200
I hope that this makes sense to you.
Sep 04, 2014 | The Learning Company Achieve! Math &...
Why can't i see this integer as a fraction
By hand you can write every integer you wish as a fraction with denominator 1. 4=4/1, 13=13/1. You can even generate all the equivalent fractions of any integer, for example -4=(-8/2)=8/(-2)=-8/2=-12/3=...
However, simple calculators are designed with a feature called automatic simplification. That is why ever result that is a fraction that is equivalent to an integer is written as that integer. Fractions are reduced to their simplest form. Call it a design flaw if you want but that is how it is.
Oct 12, 2013 | Office Equipment & Supplies
How to find remainder as a solution in CASIO fx991ES
Finding the remainder from a division calculation is often referred to as using the MOD function, though this isn't available directly on the fx-991ES.
To obtain the remainder, for example when dividing 10 by 7, you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg when dividing 389487 by 31 (equivalent to 389487MOD31) the division gives an answer of 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD or remainder calculation involving integers has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculator's working capacity.
An alternative method which avoids the rounding of the fractional part is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Dec 16, 2012 | Casio FX991ES Scientific Calculator
How do you convert milimeters in to fractions?
I am sorry but the question does not make sense. The millimeter is a unit of length (physical unit), while a fraction is a mathematical object that is defined as the ratio of two integers. It involves dividing two integer (whole) numbers, such as 1/3.
Would you care to reformulate the question?
Jun 11, 2012 | Texas Instruments TI-84 Plus Calculator
How do you represent the set of rational numbers in symbol form
hi maybe the formula below will help you
A rational number is a number that can be expressed as a fraction with an integer numerator and a non-zero natural number denominator. Fractions are written as two numbers, the numerator and the denominator, with a dividing bar between them. In the fraction written mn or
61f3a73e6711407c72f79e8deb797c6a.png m represents equal parts, where n equal parts of that size make up one whole. Two different fractions may correspond to the same rational number; for example 1⁄2 and 2⁄4 are equal, that is:
38aeb170898abdf282b4ef5400015067.png If the absolute value of m is greater than n, then the absolute value of the fraction is greater than 1. Fractions can be greater than, less than, or equal to 1 and can also be positive, negative, or zero. The set of all rational numbers includes the integers, since every integer can be written as a fraction with denominator 1. For example −7 can be written −7⁄1. The symbol for the rational numbers is Q (for quotient), also written d45a4aa156a8ac07ab80e7d9cf5fa79f.png.
Jun 27, 2010 | Cobra 29 LTD CB Radio
Can't find fraction button.
There is no fraction button, but if you divide two integers (whole numbers) and want to keep the result as a fraction press [MATH][1:|=>Frac] [ENTER]. If the fraction can be reduced to its simplest form that is the result you will have.
27/48 [MATH][1:|=>Frac][ENTER] displays 9/16
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
Casio FX-115ES Scientific Calculator Logo
104 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
