Question about Jac Health Care Products Health & Beauty
Trying to get replacement small forward wheel for a wheelchair. There is a label that says JAC. No other reference to the manufacturer. Where can I get replacement parts?
  • 175 Answers
Here's the best, cheapes and most helpful folks for tires, wheels, etc.
http://www.edmond-wheelchair.com/
There should be a number on on the side of the tire indicating its size. Jot this down and call the folks at Edmunds an they can set you up with what you need.
Posted on Jul 24, 2009
When my daughter goes down a ramp the wheelchair tilts forward and the back wheels are off the ground! Why is this happening?
ramp too steep and not made to a safety standard
person too high in chair
person too far forward in chair
front wheels not positioned far enough forward
carer not paying attention to the ramp and possible risks
talk with disability persons equipment retailers as they have a good idea of the risks involved with wheel chairs and can advise you on how to overcome the problem
Jun 21, 2016 | Health & Beauty
I have several wheelchairs in which one of the wheels stops touching the floor and just spin while the occupant is moving and trying to turn.
Depending upon manufacturer, the chair wheel height must be set up as per the manual otherwise wheels will spin.
Aug 05, 2014 | Health & Beauty
MPV4 - Right wheel is semi locked
Could be a number of issues here.
Caster bearings need cleaning\replacement
Fork bearings need cleaning\replacement.
Drive Tires could be too low and need air.
Motors were not properly mounted to gearbox and/or motor coupler is damaged.
Too much crud is wrapped around a wheel - obstruction.
The VSI controller isn't flashing a code so you are electrically connected to the motors, brakes and batteries. Problem appears to be mechanical - not electrical.
Feb 04, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Black on the wheels
most wheelchairs have gray tires, just for that reason. depending on the surface black tires almost always leave marks. simplest fix is to replace your tires with grey ones. if grey tires are on your chair now (which i suspect) then look for grease leaking from your motor gearbox. replacing motor (gearbox) is most likely necessary, repair is nearly impossible, call the manufacturer, 1 800 800 8586
Aug 07, 2012 | Pride Jazzy Select 6 Indoor Power...
I do not have the manual to my fathers charger,it makes a buzzing noise when i plug it in and says refer to operating instructions, can u help?
search the web for the charger manufactures web site,
they usually have a service section to download manuals.
if not . then send me the details on the label
Jan 31, 2010 | Sunrise Medical Health & Beauty
Forward/reverse pot is flaky, where can I buy one?
You will need the make, model and the serial number off your scooter. The serial number should be on the frame down under the shroud cover under the seat. Call the manufacturer with this info, and they will either issue you a part, or usually, refer you to an authorized repair facility for replacement of the part. Replacement is pretty straightforward once you have the tiller shroud opened up. Good luck.
Jul 23, 2009 | Shoprider Scootie TE-787NA - Power Scooter...
Chair will move forward and backwards OK but either will not turn or will go around in a circle very sharply
one of the motors is bad or has bad connection. try raising the chair so the drive wheels are off the ground (free-wheel) turn power on, push joystick forward and watch for drive wheels to turn. the one that wont indicates a bad motor or connection.
Jul 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Apr 28, 2009 | Pride Mobility Products Used Jazzy...
Motor Wiring
Two white wires are for the electric brake.  When the wheelchair is turned off while on an incline, the motors automatically lock up, preventing the wheelchair from rolling backwards.  The white wires disengage the electric brake when power is applied.
Jan 02, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Wheelchair support
First of all, you should be aware of your Center-of-Gravity. Many activities require the wheelchair user to reach, bend and transfer in and out of the wheelchair. These movements will cause a change to normal balance, center-of-gravity, and weight distribution of the wheelchair.
To determine and establish your particular safety limits, practice bending, reaching and transferring activities in several combinations in the presence of another individual BEFORE attempting active use of the wheelchair. roper positioning is essential for your safety.
When reaching, leaning, bending sideways or forward, it is important to use the casters as a tool to maintain stability and balance. When you are reaching, leaning and bending forward, position the casters so that they are extended away from the drive wheels and engage wheel locks.
Never attempt to reach an object if you have to move forward in the seat or pick them up from the floor by reaching between your knees. When you're reaching or bending backward, position wheelchair as close as possible to the desired object.
Position the casters so the are extended away from the drive wheels to create the longest possible wheelbase.
Reach back only as far as your arm will extend without changing your sitting position. When another person is tipping the wheelchair, he should grasp the back of the wheelchair on a non-removable part.
Inform the wheelchair occupant before tipping the wheelchair and remind them to lean back.
Be sure the occupant's feet and hands are clear of all wheels and/or any other pinch points.
Sep 14, 2008 | Jet 1HD Power Electric Wheelchair
Health & Beauty Logo
73 people viewed this question
Top Jac Health Care Products Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jac Health Care Products Health and Beauty Expert? Answer questions, earn points and help others
