Question about Yamaha HTR-5850 Receiver
Turns off after a few minutes
I am watching a movie for 1-5 minutes and it just shuts down. When I turn it on it briefly says "Check SKR Cables". I try to watch a movie again. Rinse a repeat. I just moved and don't have my rear speakers hooked up. I tried just attching cables for the rears with no speakers...no difference. It seems to shut off at loud point (like when the sub kicks in) I tried running the Reciever & Sub into their own outlet in case power was an issue. No change in the problem. thanks
    Problem Solver:
  • 12 Answers
Sounds like a possible power short, especially if you have speaker cables connected to the receiver but not to speakers -- leaving the ends more likely to short (even via a single thin copper strand across a millimeter or two, when the voltage peaks). The receiver's message says "Check Spkr Cables," right? (They do mean the Speaker Cables!) Most receivers have a built-in power overload detection/protection shut-off circuit to save you from such mistakes.
Posted on Jan 28, 2010
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Can't get the tv back on the channels properly after watching a m
Change the input, look for the button on the remote or on the TV itself. Just changing the channel on the TV after powering down the VCR should also work.
Sep 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Shuts off after a couple minutes
sounds like it's overheating. Clean out all the dust from it.
May 15, 2009 | Optoma H30 Multimedia Projector
Need Help
Sounds like you have a loose cable. Check that the connection is really in well. If the problem continues I would get a new set of cables, especially if you are using the ones that came with the receiver or dvd player.
May 05, 2008 | Audio Players & Recorders
Amp protection circuit
disconnect all speaker leads at the unit,power it up then see if it'll stay on. if it does, reinstall one speaker lead at a time until it goes into protect mode. that speaker line will probably have a short in it. Just run a peice of skr wire straight from the unit to the sspeaker in doubt, hooks em up see what happens. if it shuts down have that skr ckd.if it works, just rip out the old shorted line and run new stuff.
Dec 29, 2007 | Onkyo TX-NR801 Receiver
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Yamaha HTR-5850 Receiver Logo
184 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
