Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
John Deere starts quickly in Summer but very slow to start below 5 Celius . If you heat it it will then fire up. Is this a problem with injecters? (1996 model)
    President:
  • 1,627 Answers
You need to push in on the key in the run position to activate the preheat function.Leave it in for about 15 seconds or more and it should start fine.
Posted on Oct 20, 2009
  • 202 Answers
My guess is the oil is too thick (high viscosity) read the manual and see what the mfg. recommends in this low temp. enviroment.
Posted on Jul 18, 2009
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
I have a John Deere 445 and I have recently replaced the fuel sending unit clean the fuel lines out cleaned everything engine will start for a brief second when choked but will die shortly after
not familiar with this engine... I think it's fuel injected. if so , did you purge the fuel line of air? many tractors with injection, will purge if you turn the key to the Run position for a minute or two
Dec 31, 2015 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
John Deere 790 stalling out
My problem with my John Deere 790 stalling was my safety seat switch. It's a quick fix! What I had to do to fix my 2006 John Deere 790, was:
1. Un-hook the switch wires under the seat that connect to the seat switch.
2. Then, connect all of them with little wire clamps (or you can use a raw wire and connect them all) inside the wire connector, with the 4 connectors in it, to bypass the seat switch. Hot wire all of them together. It somehow resets the switch.
3. Then, with my 790 Deere in neutral, I started it up and held the key in starter position for about 2 seconds. (Instead of letting go right when it fires up) Somehow, in doing this, the seat switch reset and I was able to reconnect the switch and the seat switch works as it should now. My Deere 790 front loader fires right up without stalling now, while in neutral, of course. So, try this first because it's a quick fix. I hope this helps.
Cheers,
Aaron
Nov 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
We have a John Deere peg perego gator that was working fine last summer and this summer will not even start at all. The battery is charged. Any suggestions?
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Jul 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a 1969 John Deere 4020 that is cold blooded. It turns over fast, but won't start without being pluged in or using ether below 70 degrees. What are the potential problems?
Cylinder Compression Low, Valves worn ... not seating properly, valve stems.
Injector nozzles worn ... dribbling rather than precise squirts, injection pump worn.
First and easiest thing to do: pull all nozzles and have them tested, pull the injection pump and have it rebuilt and re-calibrated.
*NOTE: you can pull these, but are components that proffessional need to rebuild and calibrate. Truck shop, or farm tractor shops have places that specialize in this type of work.
If it is gasoline, I would look towards pistons, rings, valves.
Nov 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
182 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
