Hi! Error E20 means there is a problem with water draining. Please check the drain hose which may be kinked or squashed or the drain pump may be blocked. Another possible cause is totally blocked filter which is required to be cleaned to resolve the issue. Thanks for using FixYa and revert for further assistance. Thanks Rylee
I have a few problems, it was flashing E90,E20,it's leaking underneath, the pipe is not kinked, I...
(More)
I have a few problems, it was flashing E90,E20,it's leaking underneath, the pipe is not kinked, I can't get the front control panel off to sort out E90, don't know how to get the setscrews(not sure if that's what there called) out. It fills with water but doesn't drain or spin.
Why has the drum on my washing machine stopped going round? The machine seems to be going throug the...
(More)
Why has the drum on my washing machine stopped going round? The machine seems to be going throug the cylce, but the drum is not spinning, and the clothes are coming out soaking wet and unwashed!! Thank you Stephanie
