Question about ASUS P4P800 SE (890552603657) Motherboard
Computer keeps turning off
Somtimes i have to turn of at main switch cos it wont turn on
  • yabba121 Feb 20, 2008
    computer keeps turning off
What did you change in the BIOS CMOS?
Posted on Mar 08, 2008
Check ur configuration - BIOS CMOS
Posted on Nov 19, 2007
Somtimes my truck wont start when i push in the cluch
maybe the neautral safety switch is going bad or you dont have a good connection there
Mar 28, 2014 | 1992 Ford F150 SuperCab
2003 suzuki grand vitara 5 spd, wont start pretty sure it is the clutch safety switch. Tried to bypass still will not turn on
Trying to bypass the switch will not work, cos the computer will sense that the resistance value is incorrect. You need to replace that switch.
Dec 16, 2013 | Oil Filter Bypass Valve-Motorcycle
Washer wont spin if i jump lid switch and turn by hand it will spin
call ur technician to check the belt of the machine,that is if it uses belt cos it might be weak.
Jun 24, 2011 | Kenmore 24032\24036 Top Load Washer
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
Frontload failure code
F-1= EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
Has gas, has spark, cranks, somtimes starts somtimes not
did you check the main relay fuel switch its located under the dash too the left of the steering columm very common problem and very cheap on ebay
Aug 12, 2009 | 1993 Honda Accord
Haywood 1.5hp power-flo matrix pool pump stopped working this morning --I checked and power is getting to timer ---all wires have good connections----pump is 2 years old----does the on/off switch at the...
There is a overload switch - somtimes inside the starter solenoid area.
While you have the pump disconected from mains power - check to see if pump impella turns freely.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Intermitant various washer problems
Intermittment cycling is usually caused by either a loose connection or a timer issue. If all wiring is plugged in tight than you should replace the timer.
Jan 10, 2009 | Washing Machines
1995 audi a90 no spark
Check for voltage at the coil or ignition module. If there is dc voltage, then check for ac voltage at the coil.
Do It Yourself Diagnosis and Repair
Aug 20, 2017 | 1995 Audi 90
TI-89 Problems
There isn't anything "wrong" with it.
Go to mode, and set the results of your inquiries from Exact to approx.
If you put in cos(e^2), it will print out cos(e^2) because it's the most exact it can be without going into a decimal. (cos(e^2) will be a transcendental number like Pi).
Sep 09, 2007 | Texas Instruments TI-89 Calculator
ASUS P4P800 SE (890552603657) Motherboard Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
