Question about Kenmore 800 7983 Dryer
I have an Kenmore 80 Series Gas Dryer, the heat is not staying on. I've changed the heating element and no change. It heats up for 2-3min then turns off for 3-4min then restarts for 20-40sec. then off again. NEED HELP!
  • Kenmore Master
  • 2,341 Answers
Take the vent line off the back of dryer and see how it runs,also clean out the duct that the lint filter slides into,if the duct or the vent line is filled with lint and by the way is a fire hazard and should be done every year,the dryer will not run correctly your clothes will take longer to dry and parts will fail.if the dryer is really backed up with lint you might have to take out the thermostat on the blower wheel housing and clean the back of it,the lint gets wet and it sticks to the back of the thermostat causing the dryer not to run correctly
Posted on Mar 02, 2010
  • 234 Answers
How are ya?
The heating element is supposed to cycle on and off to maintain a set temperature. If it takes too long to come back on again, then the thermistat is malfunctioning.
Take a temperature probe and stick it in the drum and let it run for a few minutes and note the temperature. Should be consistantly near 90 - 130 degrees. Good luck :)
Posted on Jul 19, 2009
I HAVE kENMORE GAS DRYER SERIES 80. last week dryer would heat for a minute then go out. Dryer would spin with no heat. Wnt to appliance store told me to change heater fillaments that one was bad after...
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 17, 2011 | Dryers
I have a Kenmore 80 series gas dryer that will not heat up anymore. I took off the small clip in front and can see the heating element start but no flame or heat . Also the dryer will make an intermittent...
check the thermal fuse on the blower housing,if it shows good then possibly the gas valves are weak on the burner tube and wont let gas into the burner
Nov 18, 2010 | Kenmore Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
I have a kenmore 80 series gas dryer. it's not staying hot. sometimes it will and sometimes it doesnt. i replaced the ignitor on it and its still not working what do you think?
This is probably the gas valve not working right. I would replace it. The ignitor is working and turning on the valve but it doesn't stay on.
Sep 03, 2009 | Dryers
Heat does not stay on
Check the high limit thermostat. You can check it using a multimeter or ohmmeter. If bad, replace it. Hope this helped.
Jul 18, 2009 | Kenmore 800 7983 Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 800 7983 Dryer Logo
537 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
