Question edited for clarity FULL 'make model (what is is).
Question moved from Cars and Trucks, which also doesn't help identification of the mk 5603 or mk5603!
Best advice right here. Also "the same as the one that is in it".
RepairTJC.comhttps://www.repairtjc.com > Guides Michael Kors use 395 and 371 pretty evenly. We recommend using a quality brand such as Duracell or Renata when replacing the battery of your Michael Kors watch .
unfortunately you can't pair an apple watch with any Bluetooth device other than your iPhone because it is an accessory and even though you can take calls and send texts with your watch it's not compatible with any device other than an iPhone but you can still take calls and texts with your watch {as long as you have a cellular apple watch}
Sorry but I have no idea what brand of battery these are or if that is unusual for this model watch to use so much power. Use name brand batteries only. Duracell is the best for long life.
Depending on what you are using the watch for it will have different battery life. Using the talk feature you should get around 2 hours, on standby about 7 days, the analog watch has a seperate battery that should last 2 years and charging the watch takes 2 hours to get a full charge.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Generally after two years power cell life will over. > are your replaced same battery? check the voltage of power cell _1.5V > Observe that seconds needle giving any jerks? if its trying to move its overhaul faulty, give it to good service center for overhaul. > If its not at all moving at all it might be coil or PCB faulty..
