Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener will not continue to open garage door.
If I press the garage door open on the main pad it will start to open, then reverse and go back to the original position and the light goes on and off 10 times. I have adjusted the force and that did not seem to do anything. If I continue to hold the button down on the pad, then the door will continue to travel and if I take my finger off the button when it is closed it stays closed. Pushing the button and removing my finger will now cause normal operation of the door closing. My unit is a model 1160 LM and does have have light sensors at the door. It will reverse automatically when it hits something. If I unhook the trolley from the garage door it responds the same way, so it does not appear that my problem is from a binding door. Can anyone help?
  • veval Jul 20, 2009
    It seems like you are prescribing the standard solution for my problem, but as I explained in my post the problem is that I have no small lights (sensors) on either side of the door. My door reverses from the the amount of pressure when it hits something. Yet I can completely free up the door by releasing the trolly and when I hit the button on opener pad to active the motor it starts to close for about 1 foot and then immediately reverses unless I continue to hold the button on pad in.
    You are right about it being my problem, but I am using the same garage door opener that I put new gears into. It did not have door sensors before and it worked.
    President:
  • 3,197 Answers
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Posted on Jul 20, 2009
  • Don Maggard Jul 20, 2009
    If the main light goes on and off 10 times you have a door sensor problem. If you have no door sensors then that is your problem.
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not close with remote. It will only close when you press the garage button
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flashing ever so slightly. Tweak the sensors a little. If you cannot get both lights to come on you have bad sensors. If this is not your symptom post back.
Sep 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door will close with the wall pad but when the remove or key pad is used the door reopens. How is this fixed?
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
When garage door is opening the safety sensors activate and starts closesing the garage door. They should activate when I close the garage door.How can I correct this action?
How do you know it is the sensors? Has this opener ever worked properly? Do the main lights flash 10 times when the door reverses? If the opener worked before have you had it apart or done some work to it?
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman garage door opener closes via the key pad and immediately reverses and reopens. have adjusted travel limit as well as force. Any suggestions
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Oct 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door move a foot, then reverses and light flicks
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each of them has a small light that is on when the sensors are properly aligned. Make sure they are on. If not tweak the sensors to align them. If the light still doesn't come on you have either a bad sensor or the wiring going to them.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with Garage Door - Stopping and Starting
If the main light is flashing 10 times when the door reverses it is a sensor problem. Make sure the small light on each sensor is lit and not flashing ever so slightly. The sensors must be pointed at one another for both lights to be on.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
364 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
