Make sure that you slide the oven door latch all of the way to the left after the clean cycle. If the latch is still positioned to the right in the locked position then the CLEAN light will continue to blink. If the door latch lever is positioned properly to the left and the CLEAN light is still flashing then you could have a problem with the latch mechanism or the electronic oven control. You can try to reset the electronic control board by unplugging the range for several minutes (or shutting off the breaker for the range outlet) to completely disconnect electrical power. If the CLEAN light still blinks after you restore electrical power then you will likely need to have the range serviced by a technician.
