Question about Whirlpool LGR3624JQ Gas Dryer
The dryer won't heat it just spins. Could the pilot light have blown out? Is there a reset button?
  • carlblank4 Jul 18, 2009
    The dryer number wasn't correct on the first email. It is a Whirlpool LGR4634EQ1, does that change you original answer about the Igniter, gas coils or flame sensor?
  • Whirlpool Master
  • 4,654 Answers
I need you to pull it away from the wall so you can open a rear door to look in to see if the igniter is glowing and trying to light the flame. Three possibilities. Igniter, gas coils or the flame sensor. I may be able to get you going. let me know, Sea Breeze
Posted on Jul 18, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jul 19, 2009
    It is good that you corrected the model number now I need you to tell me what you see like in the post I asked you.That way and the correct model number I can point you in the right direction.
    If you can answer the first I need you to pull it away from the wall so you can open a rear door to look in to see if the Igniter is glowing and trying to light the flame. Three possibilities. Igniter, gas coils or the flame sensor. I may be able to get you going. Here is my email. I got no response from Fixya you made a comment. They know about the problem. If Igniter glows we know that is good. Then you may see a flame for about 30 seconds and go out. Then the coils are defective or the flame sensor is not sensing the heat from the flame. appliancepartsse@yahoo.com
    Thanks, Sea Breeze
  • John Tripp
    Here is a few links to my website where you can enter model and part number and click find it.
    http://servicepartstec.blogspot.com/
    PART NUMBER AND MODEL SEARCH FEATURE
    http://appliancepartseast.blogspot.com/
  • John Tripp
    Were you able to see anything from the back. The problem most likely is one of those things I mentioned. Sea Breeze
Hello all i have a beko DRVS 62W tumble dryer...it has recently stopped producing heat but still spins..how do i fix this please?
You are asking a subject which can be dangerous, since there is a gas chamber and gas involved. First check that no one has turned off the gas ballcock valve which allows gas to flow to the dryer. And that your main Home Heater or stove is working. Once you have established that, depending on model there should be an automatic ignition which lights the pilot. I'm not familiar with your model, but most dryers have a thermocouple which keeps the pilot lit. The auto reset should be near the pilot device. If you could look into Dryer by removing the access door, or sight glass (if any) you should be a pilot light or an activation of the light once the dryer request heat. As said I don't know your model, but look for a thermocouple, if you don't know what a thermocouple is, go to a Home Hardware or Appliance Repair Store and request a thermocouple. You are under no obligation to buy simple by becoming familiar. The problem with giving advice with gas appliances is that other items can cause the safety to be tripped. A crack in combustion chamber, a loose screw which changed the gas to air ration, the venting of NOX requirements. It will take some thought and knowledge, and physically seeing the devices, it could be just a wire which fell off the control valve. Ideally when it comes to gas you not only need the right tools, such as water & soap (which blows air bubbles the kids use) to check for leaks, but small wrenches, and perhaps a cleaning of the orifices. A stripped telephone wire works the best. Trace the wires from the area next to the pilot to the other end, the reset button should not be far away.
May 10, 2014 | Beko Washing Machines
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
My Kenmore auto dry I no longer gets hot. I assume the pilot light went out. How do I re-light the pilot?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 27, 2010 | Dryers
How do i light the pilot of my dryer
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating up
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Kenmore 63942 Dryer
Dryer heats up then pilot lght turns off, dryer
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Whirlpool LGR3624JQ Gas Dryer Logo
259 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
