Question about Haier ESR042PWW 4.2 Cubic Foot Refrigerator Freezer Energy Star
Punctured a hole in the freezer compartment
I was trying to get rid of all the ice at the top of my fridge in the freezer compartment and accidentally punctured a hole in it and a heap of gas came out. The gas has stopped coming out but I was wondering if the fridge section will still work. The freezer part was broken anyway as the door had broken off. I have a newborn baby and keep his bottles in the fridge so need to know asap if I will need to buy a new fridge
  • 585 Answers
That type of damage is usually fatal to the unit. It is difficult if not impossible to repair in most cases depending on the metal used to make the evaporator, and what kind if equipment the repairman has. You can't fix this yourself, consult a local repairman, explain what happened, and the model of the unit, and ask if repairable what it might cost. Or just buy a new one. And NEVER use sharp objects in an effort to remove frost buildup. Turn it off, put your stuff in a cooler, and use a heat source such as a bucket of hot water in the unit with the door closed
Posted on Jul 18, 2009
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
My integral fridge has a small built in freezer at the top. The freezer door handle broke and the door would not shut properly. An engineer came out but brought the wrong part. He returned three weeks...
It is possible that in defrosting the built up ice on the freezer that you accidentally punctured a coil and that allowed the gas to escape. If you check the area you defrosted you may find a small nick. As the tech said, it should have nothing to do with the prior repair unless he was poking around in that area with something sharp. As for the long running that would not cause it to lose gas.
Jan 21, 2011 | Zanussi Z57 / 3 Bottom Freezer...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Whirlpool Refrigerator or freezer Doesnot cool
I have a similar top freezer and during the summer
I have had a problem where the frdge part does not get cold. The two holes coming from the bottom of the freezer to the fridge are blocked
with ice. I took the back part off the freezer
got rid of a clump of ice. I also used a hair dryer
in the fridge section to melt the ice in the holes.
Dec 11, 2007 | Whirlpool ET1FHTXM Top Freezer...
Water leaking inside refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds of dollars.
If you still have problems e-mail me at walkhill@cox.net
May 31, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
1,845 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
