Question about Acer Extensa 367D Notebook
Wont go to websites when Itype words- only accepts numbers
I am connected to broadband but when I type in an address it says that internet explorer can't display this webpage. The ISP help desk said that it is definitly connected because it recieves info when you type a whole series of numbers into the address bar. Its strane because when I have used dial up the address bar worked.
Really appreciate the help
The Product is Acer Extensa 2300- its not on your list.
Thanks
Thanks
Open Internet Explorer, under the tools tab, select "Internet options". Once there, select the "Connections" tab. At the top you will see, "To setup and Internet connection, click "Setup", click on "Setup", once there, click "next", On the next page, make sure "connect to the internet" is selected and click next. On the next page click, "Setup my connection manually", click next. On the next page select(Make sure it reads exactly as follows), "Connect using a broadband connection that is always on", click next. On the next page, click "finish". That should do it.
Posted on Nov 19, 2007
My daughter sent me this pictures and I can not open them...https://www.facebook.com/media/set/?set=a.10152600715256285&type=1&l=c832241e11
These are links that ARE the pics and must be clickable/blue to open a link. Just copy each link and past in your browser/address bar and click the search icon and the end or press enter. You'll see your pics.
Nov 15, 2014 | Photography
Belkin Wireless router
Is the laptop connected to the router wirelessly? because that can be the porblem if that laptop is not connected wirelessly it wont be working, so make sure that the laptop is connected to your wireless network...
Hope that helps..............
Sep 03, 2008 | Arris Wireless G Broadband Router (wr850g)
My wireless router wont work
You need to (temporarily) hook a computer up to your router using an ethernet cable to set it up properly so you can send out a wireless internet signal with it. To connect to your router with a computer simply open your web browser and type in the router's address in URL web address bar. Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
Apr 10, 2014 | Linksys Wireless-G Broadband Router
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Linskys wireless-g broadband router not connecting to network
first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
Jun 07, 2009 | Linksys Wireless-G Broadband Router
Zyxel to connect automatically
Connect your modem to internet port of the router and your computer to any numbered slot.Now open 192.168.1.1 in your internet explorer,it will ask for username and password.Leave the username blank and in password type admin.You will get the linksys page.On the setup page you can see internet connection type.select PPPoE from the drop down menu.In username and password enter the username and password which you use in dialing broadband.Scroll down and click on save settings.Turn off the router and modem.Power up your modem first and then router.Now you wont need to dial broadband.You will be connected automatically.
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Modem to broadband router
Hi ditia,
U need to connect the modem>>router>>computer..u need to login to the router by using the ip address 192.168.1.1..it will prompt for a password...enter the password to login to the router..After logging in to the router..there will be a connection type..u need to select pppoe..after selecting pppoe u need to enter the user name and password which u got from ur ISP..save it...now ur internet will work...please give me a feedback if this info is useful
Jul 09, 2008 | D-Link DI-704P Router
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Wont let me type in internet addresses- only accepts numbers
My best guess with the limited info given is that your settings on your computer are somehow not right. My best guess is your IP address is not correct. When you right click on my network places and go to properties you should see a list of connections. Double click on the one you believe is your internet. Click on the support tab and at the top it should say next to address type "assigned by dhcp" not "manually assigned". Hope this helps.
Nov 20, 2007 | Acer Extensa 367D Notebook
Acer Extensa 367D Notebook Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
