Heating & Cooling Logo
s
sanjay Posted on Sep 09, 2016
I have a window carrier ac 1.5 ton. display show 5A what is this
actronics
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Sep 10, 2016
actronics
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
32868
Points
32
Its not 5A but SA means energy saver mode.use remote to change to cool mode without energy saver.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 14, 2008
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Anonymous
  • 21 Answers
  • Posted on Jun 12, 2009
SOURCE: could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
Bill Long
  • 606 Answers
  • Posted on Aug 21, 2009
SOURCE: Carrier Durakool 1.5 ton A.C. Moter out of order
If you bought the unit new and it's only 3 months old, the motor should be under warranty and whoever installed the unit should replace the motor for free and Carrier should pay him for the warranty work.
Anonymous
  • 10 Answers
  • Posted on Oct 21, 2009
SOURCE: carrier 1.5 tons ac Indoor unit switch off and
If you have the manual the codes are listed in there. if you lost the manual, you can download a copy at Carrier.com
Anonymous
  • 308 Answers
  • Posted on Mar 29, 2010
SOURCE: I have carrier 2 ton window ac. I want to service
In North America it is 1-800-Carrier, for more information you can visit this page
http://www.residential.carrier.com/apps/contactus.jsp?b=c
Hope this helps
2answers
I have dawlance 1 ton split a.c, and display show EA error.
i have dawlance 1.5 ton split a.c, and display show EA error.
1helpful
I have a carrier window ac error coad 5a flashing for some time ac not on
Its probably not 5A but SA. And SA means sleep auto it activates on pressing the energy saving button on remote. Its not an error but a feature.
2helpful
2answers
We have electrolux ac 1.5 ton i n our ac display showing F8 it is not change in remote how remove that.
3helpful
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
3answers
WHICH IS BEST A/C NOW
Check out this site. you will get an idea about the types of AC so that you can buy it according to your choice.
http://www.hellogiri.com/home-air-conditioner-split-ac-window-ac-price-details-in-india-best-cost/
thanks for rating Good luck
1helpful
10helpful
3answers
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
