Question about Garden
Craftsman pull cord won't retract
I pulled off the plate. How do I wrap the pull cord and test to see if it works?
  • 154 Answers
Need to wind opp way to bring tension on the cord
Posted on Aug 02, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The lead on my miele hover wont go back in when you press the button ialso dont think it is out fully
This might be the spring that retracts the cord. See if you can pull it out any farther. If not then the cord could be out of the guides or the cord is wrapped on the pulley wrong. If you can pull it out and it wont retract at all, the spring is loose or broken.
Jul 18, 2014 | Miele Vacuums
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Jul 22, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
