Question about Tower Aloha Breeze Fan
How do i open to clean inside? I can see dust build up and need to clean
Go down to a local shop and ask them if they could blow out the fan for a few bucks with their compressor air supply.
Posted on Jul 21, 2009
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
Dell laptop is very hot
It sounds like you might need to open it up and clean out the insides.
If there is a build up of dust inside then the hot air will not be able to escape. If it overheats it will turn itself off.
Nov 01, 2012 | Dell Latitude C610/C600 Pentium III...
Is there any fuse inside the KH624 power supply?
Typically, there are no fuses inside these devices. You'd think that there should be - but it's not the case. Most of the time, power supply units (PSU) begin to overheat and ever so slowly die. Replacement PSU have dropped in price - like everything else. Your best bet is to replace it and maintain it from here on in to ensure a long life.
PSU's overheat and fail because of dust. Lots of it. The fan inside blows air into the PSU case to help keep the component cool. Unfortunately, dust gets blown in at the same time - and slowly builds up on all surfaces and components. The dust build up acts as a thermal insulator that prevents the air from removing the heat. A PC on the floor will have a great deal more dust build up inside than if it were on a desk top. Oh, and the fans in the PC (not just the PSU) blow dust all over the motherboard components and expansion cards inside it, too. The most expensive components are the CPU and video card(s).
Move the PC to the desk and regularly clean the components that have fans on or near them ideally with a vacuum or if unable to vacuum - blow out with compressed air to keep them running reliably.
Nov 26, 2011 | Dell L375P00 (KH624) 375Watt Power Supply
The 3 filters were very dirty - so i cleaned them . Is the something inside the unit that also needs cleaning??
Hello, it is also a good idea to check out the blower compartment for dust and vacuum if needed. If large amounts of dust build up on the blower wheel it can cause the unit to trip on the high limit switch due to low airflow.
Sep 28, 2011 | Heating & Cooling
I've lost the manual what is the maintenance on the VF 1700mx
Shredders need no "real" maintenance......if you can open the top cover once per year and clean out any debris that might build up inside...other than that just occassionaly put some shredder oil onto a sheet of the paper you are shredding to help in lubrication/cleaning of the cutting teeth of any builld-up of dust and debris that take place during the shredding process.
Jul 18, 2011 | Royal VF1700MX Shredder
Disc player grinds, will not open
You could try opening the unit by UN-screwing it.
Checking the inside for dust on tracks or rollers. Opening it up and checking if any gel might be warned away and this might cause grinding and if dust builds up the smooth operation would be unsuitable for unit. Cd unit needs to be cleaned and sometimes manual but without disturbing too much gel inside.
Mot of the time if my player grinds maybe a rubber is broken and needs to be replaced.
Most cd player are built close to each other. But single alone units might require just some logical thinking to solve.
Suggestions-
1.check for dust.
2.check for bad alignment.
3. if can do- turn on and see it grind to solve the problem.
Jan 07, 2011 | Sony CDP-C365 5-Disc CD Changer
IN MY JUST PURCHASED UNIT I HAVE ENCOUNTERED WHAT APPEARS TO BE DUST OR PARTICLE SPECKS IN THE VIEWING SURFACE WHICH ARE MOT RELATED TO THE NEGATIVES OR SKIDES. I HAVE SCANNED APPROXIMATELU 900 SLIDES AND...
Most of these devices have photoelectric sensors build-in, which tells the unit whether there is too much paper dust on the sensors, When there is too much paper dust covering the sensor, the device will report to the User that there is too much paper dust on the sensor, and the device will not function properly, due to the build up of paper dust.
Get a can of compressed air and gently spray inside the device, to remove the build up of paper dust,
-a.
Dec 06, 2009 | Pacific Image Electronics Memor-ease...
Why does our xbox 360 make so much noise when running
The possible and most likely culprit is that after a while the inside of your 360 collects alot of dust and that dust builds up inside and on your fan. So I suggest you goto any local Walmart, kMart, Computer Store and purchase a can of that compressed air and use that to blow the dust out. Do not use a regular compressor because condensation builds up inside the compressor and will blow alot of water into your system and if you blow water in your 360 and plug it in you are going to have bigger problems than a noisy fan. The best fix is to actually open the case and clean it out that way. But by doing this you Void your warranty with Microsoft. So that is on you.
Sep 28, 2009 | Microsoft Xbox 360 Arcade
Samsung DLP TV picture is blurry and washed out, has a new color wheel and lamp
this could be a dust build up in side on the mirrors and dmd chip open it up and care fully clean the inside with some caned air
Jun 30, 2009 | Samsung DLP HL-P5663W 56" TV
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Tower Aloha Breeze Fan Logo
623 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
