I have onida dvd modal no. is dfx-2000. it having
I have Onida dvd modal no.. is dfx-2000. it having one multi led light when i plug-in to power supply, light start in red and when i press the on/off button the light becomes green...but system dose not working when i press to off it the green light still remain ...green light should be red..i checked power supply in-put to dvd mother board all in-puts supply are ok..... please show me how i can follow the circuit, can u give me some tricks & solution via diagram..... to solve this problem..
Plz change ur dvd player bcz it was 2 old
Posted on Apr 05, 2012
  • Shubham10795 Apr 05, 2012
    Chek your antena
SOURCE: dvd player(onida)
DVD players not read DVD
Posted on Sep 23, 2008
  • 2385 Answers
SOURCE: my onida dvd player cannot play mkv & rmvb
if it has no capability to play such files then there is no way to upgrade it.
Posted on Sep 19, 2009
  • 4090 Answers
SOURCE: ish noise in onida 21
check the antenna coupling
Posted on Nov 29, 2009
Testimonial: "pls answer for this qus"
SOURCE: i have onida dfx-7100 dvd player. its not reading
onida dfx 7100 standby not working
Posted on May 13, 2010
  • 49 Answers
SOURCE: My onida DVD player disc
check loading motor voltage if it is normal replace belt.
Posted on Aug 11, 2010
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
BXR 1220 is compatable with onida DFX-5965 DVD Player
It is, as long as you know where to power your Altec Speaker. Since it is USB powered, i think you need to plug it in a USB adapter for AC.
Jan 20, 2011 | Altec Lansing BXR1220 2 Speakers
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
Sep 16, 2009 | HP Computers & Internet
VIORE tv/dvd combo
If the red light flashes at plug in you likely have a main board that is bad. If you have to press the power button before the red light flashes you likely have a bad bad supply board. This will need to be diagnosed by a technician to be sure of the problem.
Aug 18, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
