Question about Whirlpool Inglis IP4400 Washer
New inglis washer expells water when fills
I've bought a brand new inglis washer it expells water out the drain tube AS the machine if filling up with water. I inadvertantly left the cycle for about 10 hours only to find the water running out of the drain tube. THanks Model number IV4500
    Sergeant:
  • 363 Answers
Seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Posted on Aug 27, 2009
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washer fills but drains at same time
Chgeck that you drain hose rises above the water level before going into the drain. If not then the water will siphon out as you put it in. The drain hose must go UP above the top of the washer and then DOWN into the drain.
Nov 12, 2009 | Whirlpool Inglis IP4400 Washer
Washer will not fill up with water...runs right back out of drain tube
Make sure the drain pipe is at least 34 inches above to bottom of the washer and that it is not sealed at that point. This will prevent siphoning.
May 26, 2009 | Maytag Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washer tub won't fill up with water
Sounds like you may have a siphoning problem. Have you checked the drain line by pulling it up out of the standpipe while the washer was filling? You may have a vacuum causing the water to constantly siphon. The following link explains this:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Having the drain hose high enough may not be the problem. You could very well have the hose stuffed in the standpipe too tight, or placed in the pipe too far. Please doublecheck and let me know if you need further assistance.
In addtion, please post the make and model number of your washer for better advice.
Aug 27, 2008 | Washing Machines
Washer will not expel water
yes. replace the drain pump motor.
Jan 04, 2008 | Kenmore 43142 Front Load Washer
Whirlpool Inglis IP4400 Washer Logo
492 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
