Question about Sony Cyber-shot DSC-W170 Digital Camera
The screen shows black lines on both sides of the picture when I turn the camera to look at the picture in the opposite way.
  • Sony Master
  • 5,839 Answers
If the image is in landscape format (i.e. wider than it is tall) and you look at it in portrait format (i.e. taller than it is wide), the camera keeps the same image proportions. Therefore, the edges have to be filled in with something, which is usually black, as it is non-distracting. Don't worry, the actual image itself will nor be affected.
Posted on Sep 08, 2016
    Sergeant:
  • 180 Answers
It may due to the screen problem
SOURCE:
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
After turning the tv on after buying it yesterday, we noticed that there was a line on th opposite side of the screen, sort of a faint line, like when you watch shows that arent wide screen, well yeah...
business 10000: Buying T-CON/ caps for the TV that just bought a couple days ago?
Are you talking about black bars on the left and right side og the pictures? Try using 'FORMAT', 'ASPECT', or 'ZOOM' on the remote to fill up the screen.
Dec 02, 2010 | Televison & Video
Nothing or black screen shows up when pic is taken
The problem is with the software in the camera! So take your camera to the nearby service center and do a format of your camera! That will fix your problem. Also check whether there is any problem in ur LCD screen!
Aug 01, 2010 | Kodak EasyShare DX4530 Digital Camera
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
Took pictures even when screen was black, now shows black picture
CCD IMAGER FAILURE !
u can call Canon and try for free repairs they have issued service advisory for various models i am sure they will cover it free of cost just give them a call in ur area and they will send a postage paid envelope for that
see this link for help on this problem
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls Rate me FIXYA for help
Apr 03, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
