Westinghouse air swing rotaryhigh performance compreessor air con.
I brought it cheap almost brand new but the owner had pulled it apart and i now think the wires are wrong as the heater does not work and the cooler part cools but not as cool as it should be . i think he swapped a wire somewhere to cause this to happen .being on a pension i was hoping to check it myself (have elect training ) to see if that is the prob.just knowing from where and to where each wire goes would help me greatly.thank you in advance
  • daddz2 Nov 20, 2007
    ok i found it finally.serial number 248 30125 model we 156 thank yuou any help is appriciated
  • 447 Answers
If you give me a model number ill try to get you a wiring diagram
Posted on Nov 19, 2007
Westinghouse UW40T3PW Screen. Wondering if it's the panel, t-con board or ribbon connector? I don't have the remote for a factory reset but I don't think that'd help. Any suggestions appreciated!
If you wish to get some details; visit the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 30, 2016 | Westinghouse Televison & Video
What is the best size kw. ANY BRAND Air Con is Equivalent to suit Air Con : Conia Air Con Model : CA242 S/N:ca24220970353
KW is not the number that you need to be concerned with. The newest rating for HVAC is called SEER. If yours is older it might be listed as TON.
Dec 09, 2016 | Heating & Cooling
We have a westinghouse tv SK-26H730S and it has black horizontal lines when you first turn it on (15 Minutes) Westinghouse say it is probably the T-con board.
The TCON board or the LCD panel is Faulty. Can confirm by replacing the TCON board .
If you wish to get some details; check the site linked here. Pull up older posts..
Jun 10, 2016 | Westinghouse Televison & Video
Westinghouse VR-4090 Issue double image on screen. I disconnect the right ribbon from T-Con to LCD go's away. Bad T-Con board?
Possibility. Replace the same and check. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 26, 2015 | Westinghouse Televison & Video
I have a 2004 deuce2. At the bottom of the rake there is a gap abou3/16 of an inch. A little grease has seeped out. Is this gap suppose to be there or is there a problem? Thank you one and all. Ride...
Hello if the neck has a zert fitting grease w/ red tacky grease wrap a rope around the lower gap area this forces it to fill both bearing areas ..i think gap is OK.. jack up front end 7 pull on legs do you feel any wiggling ..does it ride OK ,,do the swing test when in air swing front end should swing 3 times & stop ,, you can get more ans at harleytalking,con.. good luck..
Apr 28, 2011 | 2004 Harley Davidson FXSTD - FXSTDI...
1999 323i air con is freezing then becomes hot and humid
sounds like there is not enough r134 coolant in the system and when your slowing down the compressor stops turning. Have someone add some coolant and you should be ok.
Jul 01, 2009 | 1999 BMW 323 Series
Single handle tub/shower leaked, now not working
you may have installed the stem incorrectly or something is blocking the water passages inside
Apr 11, 2009 | Plumbing
White 'dandruff like' flakes blowing from front & back of air con
this stuff is mold and mildew that builds up in the blower and evaporator section of your unit the unit needs to be cleaned out i'm not familar with this particular brand so I cant tell you how to pull it apart but since it is a split system this means the freon lines will most likely have to be pulled loose. you may try removing the covers and vacuming the unit as well as you can and possibly blowing it out with compressed air. aside from that I would recomend alling a qualified service comapny. good luck peyton
Jan 30, 2009 | Maytag MBB1956GES Bottom Freezer...
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Heating & Cooling Logo
453 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
