Question about Plumbing
1hp Water Ace dual jet water pump hums, doesn't pump
I just bought 1hp Water Ace dual jet (well) water pump . I moved the switch f/ 230 to 115 as indicated and filled it with water, and plugged it in. it just hums, no pumping...
  • 1 more comment
  • wiseman3 Jul 18, 2009
    I am just using a 110 outlet that goes to a single breaker
  • wiseman3 Jul 24, 2009
    Problem is now solved!!!, I had it wired correctly, but the problem was too much back pressure. Once we cleared up the air lock, air and water exploded from the suction tube coming from the well and the motor was able to spin. I now have a primed pump. Thanks to everyone who tried to help!
  • seth veloso May 11, 2010
    are you sure you are using 115 volts and not 230? do not move the switch until you are sure, you could burn the motor up.
    Scholar:
  • 89 Answers
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Posted on Jul 19, 2009
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
New motor, will not start - only hums
voltage set right? motors come set from factory 240 v .. or you might have moved the start switch, it's at 6 0clock on the motor make sure its centered (back of the motor) shaped like a v.. looks like this.click on this
also might be a bad start or run capacitor..or a dud motor
hope this helps
jay the pool pump motor repair guy in longwood Florida
Sep 05, 2012 | AO Smith Pool Pump Motor 1HP Square Flange...
Ok my ace 2000 disposal hums. blades move freely when i put my hand inside. the 1/4" allen wrench doesn't fit in the opening at the bottom. my sink fills with water but eventually drains, so I...
Sounds like the starter winding is bad.
The cutter disc is welded directly to motor shaft. So is the allen wrench fitting.
So if disc rotates freely, then you should be able to feel the allan wrench fitting rotate too.
Use broomstick instead of hand down disposal.
If motor hums and cutter disc does not spin, but cutter disc can be moved freely, then disposal needs to be replaced.
I wish they made repairable motors so that metal and copper doesn't get thrown into the scrap recycle metal bin.
I wrote ez disposal replacement tips:
http://beta.fixya.com/support/r7929008-replace_garbage_disposal
Oct 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Installed a 1HP utilitech convertible jet pump, it is not pumping water from the well into our house. We are without water and desperately need help resolving this issue.
ensure that you have filled your water from the footvalve till the motor. if not fill it with water. then have a try.
goodluck
Sep 04, 2011 | Computers & Internet
Pump stopped pumping water, only hums when you activate the floating switch
Is there something stuck in the pump rotor if not the start winding went bad
Mar 03, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a brand new 1hp water ace water pump 230/115 switched to 115. The motor hums for 30sec then stops, but the pump does not turn. Then it will hum again in about 4min. I shut it off after that.
If it was initally wired for 230, I question who rewired it for 115, the reason is 230 is a foreign relation in the metric world, 220 in our world, in which case two of the wires wires hooked up according to non American standards. The scamatic showed the change over inside the cap, but in china the white is the ground and the green is reversed with the red to make the motor in reverse, confused, you should be, cause I'm not looking at the motor so there is no way for me to know what you have there! What I'm saying is stop before you burn up the motor and take it to a motor shop that knows about the proper rewiring to change it from 220 to 110. 4 Min. is a long time, you may have already fried it. Good Luck!
Jul 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Plumbing Logo
677 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
