Question about McCulloch 10" Electric Pole / Chain Saw
The pole adjustment tightening screw cap on my ms 1015 cracked
The extension poles plastic adjustment tightener cracked, and is not fixable.I can';t find anyplace that sells thia part. if anyone knows where I can buy one, or if anyone has a broken saw / pole that can send me it please reply to vspeziale@aol.com
  • 157 Answers
Go to ebay and post to want it now under chainsaws
Posted on Sep 18, 2009
Poor directions how do you use the adjustable stand
Alice if you are talking height adjustment, if it has this feature you will loosen the plastic collar/nut that is located approx. half way down on pole of stand, pull up on fan pole to raise and push down to lower, when at desired height tighten the plastic nut/collar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
Jun 05, 2016 | Cars & Trucks
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Can't elevate the pole
Hi, on the center pole there is a collar that turns, raise the pole then turn the collar clockwise to tighten, hope that helps
Feb 02, 2014 | Invacare 4 Leg I.v. Pole
Clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
Dec 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
The tightening screw for the main pole of my quantaray QSX 9002TM tripod broke very easily after I was careful to never over-tighten. Is there any option than sending the entire unit back to quantaray...
I had the exact same issue. I found a snapper tubing clamp at an aquarium store that works perfectly. Do an internet search on "snapper tubing clamp" or "snapper hose clamp", you'll find many suppliers. These clamps are good because there are many sizes, they are fairly adjustable, and easy to release. I set up the tripod, slide/attach the clamp on the main pole right above where the screw used to be and tighten the clamp until it doesn't allow any sliding.
You might also get lucky and find an adjustable tube clamp at a bicycle store or music store.
Jun 18, 2010 | Photography
Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
The large black outer plastic nut that tightens to hold the saw at desired length has cracked and will not tighten. Can I buy a new one?
What Jerr isn't telling you is the link is worthless. RemingtonPower is no longer in business. Sorry
Lou
Nov 06, 2009 | Remington Electric Pole Saw
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
Fingers on pole adjusting/tightning mechanism broke and now I can't tighten or use pole saw.
It depends on what pole you have if the part is available. You may have to get a whole new pole. I suggest you contact Master Parts at 800-446-1446 or you can find them on-line at www.masterparts.net. They should be able to help you.
Apr 20, 2009 | Remington Polesaw Wizard
McCulloch 10" Electric Pole / Chain Saw Logo
201 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
