Question about Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer kept beeping during the entire cycle (on every type of cycle) replaced the control board now nothing works?
  • 15,935 Answers
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE top load washer seems to work fine, but I get a beeping sound about every minute during the wash cycle and after it is complete.
If you are referring to a constant, or random audible beep that occurs whether the washer is running or not, this is a well known problem with the Oasis. The User Interface Control board behind the control panel is the cause. The following links explains the problem in more detail:
http://www.fixya.com/support/r4218022-kenmore_oasis_constant_audible_beep
If the control board connector plug appears to be intact and corrosion free, and unplugging the washer for 30 minutes does not clear the problem, more than likely you will need to replace the user interface.
If you have questions about this repair, please post back and let me know. I hope you find this information helpful.
Jun 28, 2010 | Washing Machines
Intermittent beeping and now after you set the
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Mar 31, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine keeps beeping
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!
Mar 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Oasis washing machine keeps beeping during the wash cycle..
Jan 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Top Loader Washing Machine
Jun 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washing machine, less the 2 years old
Mar 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
Kenmore oasis washer
This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
Aug 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
123 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
