Question about Garden
Ryobi 725 R runs only when choked, full throtle
With fresh spark plug, fresh gas, cleaned exhaust ports (they were clean), disassembled and reassembled carb, (it was clean, but did not install any new parts) will run when choked at full throtle. If choke is opened unit stalls, how do adjust carb needles? They have red and yellow caps and do not seem to turn. Unit has a blower and string trimmer heads.
  • 130 Answers
You will have to rebuild carb.red and yellow caps just pull off you might have to get a tool to ajust carb and take them out
Posted on Jul 18, 2009
Why does my edger stall when you take choke off ??
Carburetor adjustment required.
Most common items to check when sm. Gas engine won't run at full capacity (like choke off, or full throttle) are simple maintenance procedures. Check the following when engine bogs, clean or replace...
  • Spark Plug
    • When dirty with carbon buildup, proper spark gone - can't provide for good ignition
  • Fuel Filter, it's probably in the gas tank
    • When dirty, good flow is pretty restricted, engine starves for proper amount of fuel
  • Spark Arrestor Screen, at muffler
    • When all clogged up, exhaust flow is very restricted, creating back pressure = bogging engine
  • Carburetor, may need a rebuild kit
    • When dirty, clogged up and plugged up with build up of sediment, fuel flow is pretty much, down to a trickle. A good cleaning is usually the fix - a replacement of integral parts found in a rebuild kit = Time Well Spent
    • Then make sure you adjust properly
Look here...
And...
One more...
Jun 13, 2015 | Ryobi Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan bv200. will not throtle up. it starts with choke at1/2 and throtle at 1/2. new spark plug and clean air filter. when i try to zero choke it dies. and at full throtle it will not get to full speed...
The unit is lean. rebuild the carb with a carb kit and check your fuel lines. If they are brown or discolored or brittle they need to be replaced. carb kits run approx. 11 - 18 dollars from your local dealer.
Nov 23, 2009 | Poulan Garden
Ryobi trimmer stalls when we move from full choke to Half choke or Run. Tried cleaning the air filter, changed the spark plug.
Try cleaning any carbon build-up at the screen on the exhaust port. I use carburator cleaner, a small wire brush, and a small screwdriver. Carbon buildup at that area can cause this type problem. I would clean the carburator as well. Hope this helped and best wishes.
Aug 31, 2009 | Ryobi Garden
Ss30 won't idle after starting
Hi Steve,
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Garden Logo
336 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
