Question about EliteGroup P4VMM2 Motherboard
Hard network i have some little bit doubt whole motherboard and how is contacting with each other proseger
  • 119 Answers
Re: hard network
networking you need nerworking cables which connect into the slots on the back of the motherboard the plugs for the network cables look exactly like those of a telephone cable and thus the plug female slots on the motherboard look like those on the telephone box. Plug these cables connecting the PCs you wish to network . secondly, you need network drivers for your motherboard you can download these from the manufacturers site. you should now be set to go depending on whether your drivers and Hardware is compatible with your Operating system
Let me know how you do (Networking can get complicated take it step-by-step and let me knwo if you have more questions)
Posted on Jan 29, 2008
0 characters
3 Points
Upgrading bios
Hello you can download the files here:
Here is a guide, how you upgrade the bios:
Adobe reader is needed, to read the content.
You also have to setup the whole bios, when the job is done.
If any doubt upgrading the bios, let a expert do this for you.
Caution !!
We don't recommend the user to update the BIOS while the system is running in good condition. The failure of updating the BIOS due to improper operation will cause a damage of the system, BIOSTAR is assumed no responsibility. Please do not hesitate to contact us with E- Support if you have any question.
Good luck
Nov 09, 2012 | Biostar Intel H67 Socket 1155 Motherboard...
Need nec versa e 6000 motherboard faulty . where i can buy the motherboard?
it is not worth it to purchase a new motherboard for around 200$ when you can buy a brand new computer for just a little bit more.
You can have your files moved from the old hard drive to the new laptop by a professional or you can do it yourself if you aren't a complete dummy with computers.
To do it yourself you would need to first remove the old hard drive from the old computer ( NEC ) and then buy a external hard drive case for it that fits to it - there are 2 sizes, 2.5" and 3.5", probably 2.5" hard drive and then there are 2 types of connectors, IDE and SATA. SATA has a flat connector, and IDE has around 40 metal pins sticking out of it.
buy the appropriate USB caseing for it and then connect it to your new computer, you can transfer your files from it to the computer, after you have done so, you can keep the old hard drive as a external hard drive, for backups for example.
Jan 04, 2011 | NEC Motherboards
One of my friends gave me a computer which is rebuilt with diffrent parts. i dont know much about it. it has a asus tuv4x motherboard with only a 128mb and a 256mb pc133 sdram its slow idont have the funds...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
to defragment your hard drive control panel ,administrive tools, computer management you will see
disk defragment this should speed your computer up a little bit
hope this helps
Nov 26, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
Usually, this requires a little bit more info...
On motherboards these days you have different types of connections
Each has it own specifications...
Provide Operating sytem
Provide drive make and capacity
specify drive type
please tell what drive is for (replace original, or used as a backup)
Good luck
Sep 27, 2010 | Intel Motherboard
My motherboard does not work in my cabinet but if i put it out it works if you have any solution then please help my if you can thank
It sounds as if the motherboard is not correctly mounted. make sure that the screws you use are the correct ones for the job. They must only be placed in the "mounting holes" on the motherboard, not any other.Those holes have a contact to earth the board with the case correctly.
2. Are you sure it is not cracked? when you install it and screw it down the crack can open a little bit. Try not screwing it down tight, to test that.
3. Check that the memory is actually fully clicked in the slots.
Jul 04, 2010 | Motherboards
Ethernet Controller Compaq Evo D310m Intel Pro 100 VE
try using Microsoft update to scan for driver and software updates.
Feb 13, 2009 | Compaq Evo D310M 845G P4 Motherboard
Where i can find intel desktop board proseger chip
down load driver for mother board driver intel d845gvsr
Feb 07, 2009 | Intel D101GGC Motherboard
Dual channel problem
Is the 2 GB of memory in two identical 1GB sticks? what slots are they installed in? Check to make sure they are installed in slots 1 and 3 (usually - I dont know what motherboard you are using.), and the motherboard is enabled to dual channel mode .
Mar 15, 2008 | Motherboards
Having problems with slowdowns, network card, hard drive.
Yes first of all you are telling me that your pc crash when you insert the network cable. What you can do is to try installing another operating system or service pack, maybe it is caused by a bad ram,resource conflick,bad network connector on the cable,also see if your network card has not the same address as another hardware ,this will make a conflict which will definitely caused this type of problem,if not so reset your bios
Jul 05, 2007 | ASUS P4S800D-X Motherboard
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Michael Thomas
Michael Thomas
Are you an EliteGroup Motherboard Expert? Answer questions, earn points and help others
