No symptoms stated, just a silly easter egg hunt, is this fun ?
nor engine size nor transmission(matches)
i posted the free FSM 300 times here, cant read that?
its free
and covers what you have,. the trans, and every part in it.
301 times.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
ZJ jeep
read chapter, 21 13kb file, is it. last in trans list.
42RE
44RE?
or?
end easter egg hunts.
It's called a governor. It is a solenoid inside the transmission. Pull the pan, it is on the passenger side. You will see 2 plugs, one is the governor solenoid, the other is the pressure sensor. I recommend you replace both.
SOURCE: 1998 jeep grand cherokee
Under the glove box beneath the dash the resistor should be screwed into the heater housing.
SOURCE: LOCATION OF LIGHTER FUSE FOR 1996 JEEP GRAND
If you have the owner's manual look up fuses in the index, good illustration. If you don't, I do. It shows a relay and a 15 amp fuse. Look at the passenger kick panel, pull the cover, and it is #2 fuse (second from the top on the left) The see the relay you may have to pull the panel (two screws and a clip) the relay is the third cavity down, third row from the firewal side.
Let me know if this works for you?
SOURCE: GRAND AM 97 VSS LOCATION
The vss is mounted on the rt axle shaft housing at the top of the housing on an automatic and man trans.
SOURCE: 97 jeep grand cherokee fuse
its in the passenger side, below the courtesy light, in front of the door hinge
