Question about PfaFF Sewing Machines
The thread keeps jumping out of the thread takeup lever on my Pfaff. What is causing this? I've replaced the needle and the bobbin shuttle.
  • jean368 Jul 27, 2009
    This isn't possible with this type of takeup lever -- it is open on top of the hole. I've used this sewing machine daily for the 27 years I have had it. It is used 3 to 4 hours a day and the thread only comes out after it has been in use for 1 1/2 to 2 hours. I'm starting to think it may be an overheating problem. This problem just developed in the last 2 weeks. It maybe just needs to go into a repair shop.
    Hi Scott,
    I was able to run the thread so it was crossed after going through the takeup lever as you suggested. 4 hours of straight sewing and no thread popping out of the lever.
    I have not changed manufacturer of thread recently. I did check the cone I am using and it is the same weight as the one I finished up a couple months ago.
    The problem seems to be solved. No idea why it just changed midstream, but I'll take it not jamming, etc.
    Thanks for all your help!
  • 55 Answers
If you have the machine threaded correctly, try threading the takeup lever from the opposite side so the thread crosses over itself and see if that helps.
scott
Posted on Jul 27, 2009
  • scott ashdown Jul 27, 2009
    you should still be able to thread the takeup lever from the opposite side. husqvarna machines have a similar problem, especially with certain thread types and this does prevent that problem. (have you changed thread type recently??)
    i don't think it will have anything to do with heat unless the thread is breaking and coming out of the needle.
    scott
Thread uptake keeps dropping thread after about 5 stitches Ive rethreaded changed needle checked bobbin area changed bobbin and still drops
Do you mean the thread comes out of the take-up lever when you sew? I have an old Pfaff that if I sew too fast, the thread "jumps" out of the take-up lever and then it's an instant mess of thread. I fashioned a small piece of tape to cover the opening in the take-lever and no more problems. Something like a drop of hot glue may work too.
If the thread is tightening at the take-up lever and eventually breaking, it is most likely because the thread is not advancing properly through the tension disk or the thread is hanging up somewhere between the thread spool and take-up lever. If you watch it closely, you may see the thread tightening and then be able to discern where the problem originates. (Make sure the thread is not hanging up at the thread spool.)
Jan 24, 2017 | Sewing Machines
ChaMy pfaff 2144 will not stitch properly; pools masses of bobbin thread; Changed thread, tensions, needle etc still wont sew, please advise as I am so desperate to fix this problem
bunching of thread under material is a needle tension problem
tighten it up
proper tension is when it requires a small amount of effort to pull the thread through the needle eye
Jul 28, 2016 | PfaFF Sewing Machines
My needle thread wrap around shuttle hook how do I repair this? on my Brothers CS 8060
Barbara,
Upper thread looping around the shuttle is typically caused by improper threading through the upper tension disks and takeup lever. Check the instruction manual, carefully rethread the top of your machine and make sure the presser foot is in the down position. If the problem continues it may indicate an issue with tension disks. Remove the upper thread, fold a clean piece of fabric and with the presser foot raised to open the tension disks, place the fabric it in the thread path, through the upper tension disks. Lower the presser foot and draw the fabric back and forth to clean any build up of grime and wax from the disks. Lift the presser foot, remove the fabric, rethread and try again.
If the problem persists, you should not need any tools to remove the shuttle to inspect it - sometimes it is necessary to remove the needle plate to lift it out. Check the edges and underside of the plastic shuttle for marks caused by needle strikes - these can catch the thread causing the issue you describe. If there are marks, you may be able to polish them out with fine (600 grit or higher) wet and dry paper. I generally replace them. Also check the tip of the hook for marks - you can often feel these with your fingernail. If they are present, you may need to get a mechanic to polish them out.
May 31, 2015 | Brother CS-8060 Computerized Sewing...
Pfaff problems, thread jumps out of the take up leaver
if possible take a piece of cloth and place it over the take up lever and get a pair of pliers and gently close the take up lever alittle bit just enough to keep the thread from coming out.
Aug 19, 2014 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
My Pfaff Quilt Expression 4.0 was working perfectly until I cleaned the lint out of the bobbin area and changed my needle. Now I have what looks like a multi stranded crochet chain on the bottom of m
Sounds like a tension problem. Remove the top thread and re-thread it while the presser foot lever is UP. Then do a test seam.
Also make sure you've replaced the bobbin correctly most machines require that the bobbin unspool in a certain direction to form a proper loop.
Good luck.
Sep 11, 2012 | Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
I need a threading diagram singer 329k sewing machine
Cotton omn the reel pin, take the thread from the right to the left and through the top cotton guide above the takeup lever, make sure the takeup lever is at the top and make sure the presser foot is up, take the thread down the right hand side, round the tension unit and back up the left hand side to the takeup lever, right to left through the takeup lever and then follow the guides all the way down to the needle and thread front to back, flat side of the needle must face back.
when you put the bobbin in, bobbin in your left hand and the thread must feed from the bottom of the bobbin, drop the bobbin, through the groove and lay the thread to the back.
Feb 12, 2010 | Singer Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
119 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
