Question about HP DeskJet 3650 InkJet Printer
The printer say offline can't get it to pring
Do you still have all of your printer software?
Did you disconnect the usb and then replug to see if your computer detects it?
You can also try restarting your computer to see if that corrects the problem..I have had this occur a few times with HP printers.
If neither of the above work try this site..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=304535
Posted on Jul 18, 2009
Hp deskje d2360 printer showing offline error
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
Message - offline --comes up when I try and pring
you should check your connection.. physically inspect the hardware and try to restart the printer. if problem persists, reinstall its drivers and all should work out.
Thanks for using Fixya
Feb 24, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I have a line matrix printer lipi 6306L. When I switch on the printer it shows a fault : Platen Cal Cable How to solve it
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Jan 25, 2010 | Tally 6312 Matrix Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Paper Abrasion
first open the printer option by cliking start -->settings-->printer and fax,right click on canon pixma printer cancel all printings, then off the pring again on it.
Aug 13, 2009 | Canon PIXMA MP610 InkJet Printer
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
At first would pring in oolor only with faded
Do several printhead cleaning via the printer menu and make a test print. Mostly printhead cleanings solve the issue.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Hp Photo Smart Printer 7760
When you open the printer control panel, is there a queue of documents waiting to be printed? If so, delete/cancel all documents, check to make sure it is set to use printer offline (in the file menu), and then try printing a test page.
Dec 11, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet 3650 InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
