Question about Sierra Online, Inc. Field and Stream Trophy Bass 4
Running tropy bass4 on Vista
I got it installed, but it won't run without the disk, and then it says I need 4mb memory, and when I click on ok, it closes the program. Surely it isn't possible that I don't have enough memory? I want it to just run once it is installed
    Scholar:
  • 83 Answers
What is the spec of your pc? as Vista requires at least 3GB to run smoothly, how much memory has your pc got?
I might be able to solve this
Steve :o)
Posted on Jul 21, 2009
Keep geting low memory and blue screen
You need to add more memory for the low memory message.
For the blue screen problem you need to run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If you get it working you might try downloading and installing MalwareBytes to run a Quick Scan for viruses and infections.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 14, 2012 | Dell Dimension E521 PC Desktop
Tip
5 ways to speed up your computer
By following a few simple guidelines, you can maintain your computer
and keep it running smoothly. This article discusses how to use the
tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to
more efficiently maintain your computer and safeguard your privacy when
you're online.
1. Free up disk spaceThe Disk Cleanup tool helps you free
up space on your hard disk to improve the performance of your computer.
The tool identifies files that you can safely delete, and then enables
you to choose whether you want to delete some or all of the identified
files.
Use Disk Cleanup to:
  • Remove temporary Internet files.
  • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
  • Empty the Recycle Bin.
  • Remove Windows temporary files such as error reports.
  • Remove optional Windows components that you don't use.
  • Remove installed programs that you no longer use.
  • Remove unused restore points and shadow copies from System Restore.
Tip:
Typically, temporary Internet files take the most amount of space
because the browser caches each page you visit for faster access later.
2. Speed up access to dataDisk fragmentation slows the
overall performance of your system. When files are fragmented, the
computer must search the hard disk when the file is opened to piece it
back together. The response time can be significantly longer.
Disk
Defragmenter is a Windows utility that consolidates fragmented files
and folders on your computer's hard disk so that each occupies a single
space on the disk. With your files stored neatly end-to-end, without
fragmentation, reading and writing to the disk speeds up.
When to run Disk Defragmenter
In addition to running Disk Defragmenter at regular intervals—monthly
is optimal—there are other times you should run it too, such as when:
  • You add a large number of files.
  • Your free disk space totals 15 percent or less.
  • You install new programs or a new version of Windows.
3. Detect and repair disk errorsIn addition to running Disk
Cleanup and Disk Defragmenter to optimize the performance of your
computer, you can check the integrity of the files stored on your hard
disk by running the Error Checking utility.
As you use your hard
drive, it can develop bad sectors. Bad sectors slow down hard disk
performance and sometimes make data writing (such as file saving)
difficult, or even impossible. The Error Checking utility scans the
hard drive for bad sectors, and scans for file system errors to see
whether certain files or folders are misplaced.
If you use your computer daily, you should run this utility once a week to help prevent data loss.
Run the Error Checking utility:
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start
  7. If bad sectors are found, choose to fix them.
Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
4. Protect your computer against spywareSpyware
collects personal information without letting you know and without
asking for permission. From the Web sites you visit to usernames and
passwords, spyware can put you and your confidential information at
risk. In addition to privacy concerns, spyware can hamper your
computer's performance. To combat spyware, you might want to consider
using Microsoft Windows Defender, which is included in Windows, Alternatively, there are other free anti-spyware software programs available.
5. Learn all about ReadyBoostIf you're using Windows 7 or
Windows Vista, you can use ReadyBoost to speed up your system. A new
concept in adding memory to a system, it allows you to use non-volatile
flash memory—like a USB flash drive or a memory card—to improve
performance without having to add additional memory.
on Jan 01, 2010 | Computers & Internet
Can u help me get rid of my pc running slow please?? i am losing it
Run Disk Cleanup
When PC is full of junk content or trash files it start performing slowly. To speed up your computer you need to delete all the trash data from your system. You can clean your PC using Windows pre-installed tool Disk Cleanup. To run Disk Cleanup follow the steps below:
  1. Click Start
  2. Type Disk Cleanup in search
  3. Press Enter
  4. Select the drive which you want to scan and click OK
  5. Select files to remove
  6. Click OK then Yes
NOTE: Follow above steps to clean all drives one by one
Run Disk Checkup
System full of errors also affects the speed of computer. You can speed up your slow computer by running Disk Checkup for detecting and removing errors. To do so follow the steps below:
  1. Open My Computer
  2. Right click on drive which you want to check for errors
  3. Click on Properties
  4. Click on Tools tab
  5. Under Error -Checking menu click on Check Now
  6. Select the options and click on Start
Run Disk Defragmenter
Due to huge transfer of data fragmentation occurs in Windows operating system. This also results in slow PC performance. Running disk defragmentation remove fragmentation and allow you to access data quickly. To run it follow the steps given below:
  1. Click on Start button
  2. Type Disk Defragmentation
  3. Press Enter
  4. Select the drive and click on Defragment
  5. Restart your computer after completing the process
Clean System from Virus
Computer infected by any malicious application also runs slow. In this case you have to download and install reliable antivirus program with up to date virus database. Run a complete PC scan and remove all the viruses detected by the program.
Repair Registry Errors
Windows registry keeps on storing information about programs installed on PC in form of keys. Corrupt registry keys cause a computer to run slow. In order to fix this issue and speed up your computer you need to install a System Utilities program which includes Registry Cleaner and PC Optimizer feature. These tools will allow you to boost your computer performance.
To download a reliable and professionals recommended System Utilities program click here.
Jul 17, 2011 | Computers & Internet
MY Laptop Is Very Slow And Crash
* check you virtual memory or adjust it...
* scan your laptop with the latest update of anti-virus,might your laptop got many viruses.
hope this solution helps..... please rate my performance... thanks
Jun 02, 2011 | Sony VAIO VGNNW330FW 155Inch Laptop White...
My windows vista laptop is running slow
The question is whether Vista is slow or the Internet. Vista needs to be cleaned if you do not have a good cleaning software program I advise this one for simply cleaning of files that are no longer needed left over installations etc, and it cleans the registry and allows you to see startup programs and other things that prevent computer slow downs. Be sure to also if you decide not to download the free cleaner program that you go to start-run-then type in msconfig and select any programs in the startup other than antivirus and click on disable for now. If when you restart your computer does fine then go ahead and repeat the process and select delete this time, this will increase performance considerably. Click Here to download ccleaner it is free. Thanks for using FixYa! please post a comment if this assisted you in any way. Also gather all of your files personal you want to keep and save them to disk or a USB stick or an external source. This will free up the hard disk.
Now in relations of the router since this is question is applied to the router section. Unplug the router and turn of the computer. Wait about 25 to thirty seconds restart them both. The Internet connection is determined by your service and has nothing to do with being slow unless your computer is bogged down or does not have enough memory or a good graphics card as well. Upgrade these and check hard drive space delete unwanted programs also. One other suggestion is to upgrade to Win 7 Vista is quirky to say the least. If you do not have the memory or other resources to run Win 7 I would consider Win XP even know they are closing out their updates it is less draining on your computers resources.
Feb 21, 2011 | Computers & Internet
My laptop is really slow
It could be due to clogged Registry. Use a good registry cleaner to do that. Even I had the same prob. my laptop used to take 20 mins to boot. After cleaning the registry it runs now.
Sep 17, 2009 | Gateway MT3705 Notebook
My brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista,...
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
May 18, 2009 | HP Pavilion Notebook
Need patch for free space 2 game to play in windows vista needs to recognize I have 4 gigs of memory
is it not installing,try to browse setup.exe or install file for the game,right click and choose run as administrator..it should be installed w/o any problems,or if you were able to install this and the game just crashes upon playing it,you need to put it to compatibility mode,To do this search for freespace.exe (Probably in C:\Program Files\Volition\", right click and select the "compatibility" tab. Check the box that says "run this program in compatibility mode for" and select "Windows 98"
Sep 29, 2008 | Computers & Internet
I've Run Out Of Memory Without Adding Anything New To The System
When you deleted files, what you are freeing is hard disk space and not memory.
What I suspect is that at startup, your PC loads a number of programs that may or may not be essential for the system operation but nonetheless uses memory. This greatly reduces available/free memory and when you really want to run an application, the PC has no more memory to spare.
The easiest way I could think of to free up more memory is to streamline your startup applications. This could be done by running your System Configuration Utility (Start/Run, type "msconfig" less the quotes, Startup tab).Try to Disable All or uncheck all entries (except perhaps your antivirus and any application that you feel may be essential).
Additionally, you can increase your virtual memory. This could be done in your System Properties/Advanced tab/Performance Settings button/Performance Options Advanced tab/Virtual Memory Change button and select Custom Size. Numbers should roughly be equal to twice your real memory (say onboard is 512, then virtual = 1024). You need to click on the Set button, OK,OK,OK and reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Dell Inspiron B130 Notebook
Sierra Online, Inc. Field and Stream Trophy Bass 4 Logo
282 people viewed this question
Top Sierra Online, Inc. Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Charles Applebaum
Level 1 Expert
Are you a Sierra Online, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
