Question about Nokia 1600 Cellular Phone
Nokia 1600 inser sim card solution My phone may have gotten spilled on and now when I try to turn on my phone, it won't read my SIM card. I have tried to clean it, but nothing is working....is there anything that can be done?
  • Nokia Master
  • 2,148 Answers
Here is your last and final solution.You can clean the sim case as well as the sim.But the main problem is if you are not a mobile tech you cannot do the job because we need to apply jumper to Sim IC (filter).No matter if you can do it look at the image Nokia 1600 inser sim card solution - raingamj_4.jpg
Posted on Jul 12, 2011
My nokia 1600 not read my SIM card
Posted on Sep 24, 2008
  • 3 Answers
1.Make sure the voltage 4V from the battery (VBATT) is supply to Spool (L2400), if OK
2. Check LED (V2400) or replace it, if the problem not solved,
3. Re-Blow/Replace IC White LED Drive (N2400) for display or Keyboard.
I hope this can solve your problem.
Posted on Oct 31, 2009
How do I put my sim card form my nokia 1600 phone into my motorola phone?
Posted on Dec 15, 2007
Dear
first of all replace and test with sim and battery . if not solved then the asip sim filter will be the problem.then you have to contact any repair centre
Posted on Nov 21, 2007
Replace asip simfilter or make it track 1 and 3,4 and 6,7 and 8.
Posted on Nov 20, 2007
    Problem Solver:
  • 6 Answers
Just clean the sim card with cotton and possible some solution which cleans Discs and insert it properly and then check it, and please let us know what is the error message you are getting.
Solving the nokia6120c insert sim problems
There are some possible solutions:-
1. Check that your sim card is in perfect condition by insering the same sim card in any other mobile phone... If the same message appears that means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by inserting any other sim in your mobile phone... Still if the same message occurs that means the problem is in your sim card's slot
3. Check that you are inserting your sim card correctly or not
Aug 27, 2011 | Nokia 6120 classic Cellular Phone
When i am switching on my phon....it is written in the screen that SIM CARD NOT VALID why??
1. Check that your sim card is in perfect condition by insering the sim card in any other mobile phone... If the ssame error appears then it means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by insering any other sim card in your mobile phone... If the same error occurs then it means the problem is in your sim card's slot
3. Check that you are insering your sim card correctly or not
Aug 06, 2011 | Nokia 6120 classic Cellular Phone
I want to swap sim card from one Nokia 1600 to another Nokia 1600.
As long as your second phone is not locked to a network that is different to your sim card, simply remove the back cover, removed the battery and swap the sim card.
If the second phone is sim-locked to a different network, you will need to get it unlocked
Oct 13, 2010 | Nokia 1600 Cellular Phone
Insert sim
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using IPA solution. This problem is caused by Firmware problem and Hardware problem as well. Good luck.
May 15, 2010 | Nokia 1600 Cellular Phone
Bought an '' unlocked'' nokia 1600 cell phone , when my active sim card is inserted , it asked for the 'unlock' code ? my codes so far have not worked ??? any suggestions ? Thanks ! d.a. ...
the phone has be locked to a particular network and that's why its asking for unlock code when yu inser your sim.
You can get an unlock code from unlock-free.com/nokia
This site will help to generate an unlock code for you.
Just make sure you read and follow instructions carefully.
Take care.
Mar 04, 2010 | Nokia 1600 Cellular Phone
What should i do when 1100 cell shows insert sim
the pins that touch the sim card could be lose or the sim card might be bad, try pulling the pins on the phone up carefully just a little so its a little more thighter to inser the sim card, then try again, also try another sim card if it doesn't help.
Jun 11, 2009 | Nokia 1100
My phone wont turn on
maybe your sim is block if you have a sim card you can see the label of sim card p,u,k pin code try to type a p,u,k pin code thats all....
Nov 17, 2008 | Nokia 1600 Cellular Phone
try cleaning the sim with a pencil eraser softly
and replace the sim in the phone.
I f you still have the same prob then your sim reader on the board is not working and it will require a hands on technician
Nov 11, 2007 | Nokia 7610
Nokia 1600 repair
see budy that might be a welcome note message if ur phone works after that, menu>>> settings>>>>phone settings there is an option called welcome note delete the welcome note and than try.
Oct 20, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 ,insert sim and not charging solution
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. try to change a new battery' or maybe the sim card driver is unsoldered' or need to replace. here is the pics. skilled technician can do. a4f7f33.jpg
Oct 04, 2007 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
242 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
