Question about Texas Instruments TI-83 Plus Calculator
Won't get off the screet that says waiting... please install calculator software now
I was resetting my whole ram for a math test which was required to do, and as the calculator was resetting itself this sign came up and won't leave it says waiting... please install calculator software now. I have taken out batteries, even backup battery, and still the same sign repeats... anyway to reset it and get it to work again
  • 3 more comments
  • Anonymous May 07, 2008
    same screen popping up and same problem..how do you fix it since taking out batteries does not help
  • kab22 May 16, 2008
    i have the same problem as described above please help asap thank you
  • kyle8525 May 21, 2008
    me too same problem
  • nlock Jun 06, 2008
    same problem. what do i do?
  • chainsawbob Oct 13, 2008
    I was reinstalling my os and the calculator suddenly locked up and quit communicating with the computer. Just says "Waiting" "Please install calculator software now." I have a TI-89 and TI-92. I connected both of them and they work fine. It is the IO of the TI-83 only?
  • 32 Answers
Well you seemed to have deleted your OS. This is easy to fix it you need to go to the TI site and follow their instructions for downloading a new os thats all you can do.
Posted on Sep 17, 2008
  • snacks tasty Sep 17, 2008
    or you can ask a friend to send you an os after connecting calculators. You do this by 2nd link and then select send os
Where is the = sign of ti84 plus
Press 2ND [TEST] 1.
TEST is the shifted function of the MATH key.
Apr 27, 2014 | Texas Instruments TI-84 Plus Calculator
How do you type an equal sign on the TI 84 calculator
On these units, the "equals" sign ([=]) is located in the [TEST] menu. This menu is a [2nd] function of the [MATH] key.
This function is used to test if two expressions are equals. To evaluate an expression, simply hit [ENTER].
Good luck.
Mar 01, 2011 | Texas Instruments TI-84 Plus Calculator
How to make 3 2/5 on device
To deal with a mixed number you must insert a plus sign between the whole number and, fraction. Such as, (3 plus 2/5). Now in your math processes to stay in this form you use the convert to a fraction command.
Jan 13, 2011 | Texas Instruments TI-83 Plus Calculator
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
The top half of my screen split into four "windows." I can't get it to go away, no matter what I do. I can still do basic math equations at the bottom of the screen, however.
It is possoàible that you activated the split screen feature. IF THAT IS THE CASE, you can deactivate it.
  1. Press the MODE key.
  2. Use Down Arrow to move focus to the 8th (the bottom) line.
  3. Use the left or right arrow to highlight FULL, and press ENTER
  4. Press 2nd key then QUIT.
  5. Main screen will be whole again.
If that does not work, reset calculator to the Default configuration.
  • Press 2nd key then + to access MEMory management.
  • Select 7:Reset
  • Under RAM menu, select 2:Defaults
  • Press 2:Reset
  • Calculator returns with Defaults set.
  • Press the CLEAR key to clear the message.
Mar 02, 2010 | Texas Instruments TI-83 Plus Calculator
Same as last time
Be reasonable in what you say especially when you seem to infer a blinding truth. If your screen were broken you would not be able to "FIX" it through a connection to another calculator.
I know. Sooner or later you will post another similar question so better learn what the real problem is.
Casino swamps your memory and messes up you calculator. If no more memory is available you cannot get any response from any key.
Play Casino as much as you want. Stop the game before you win that fateful 120000 dollars. Reset the Ram and play again.
Reinstalling the OS by connecting the calculator to another unit effectively reset the RAM and kicks casino out of memory.
To reset the RAM before the calculator is completely frozen, press [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared. Press the [CLEAR] button to erase that message.
Jan 06, 2010 | Texas Instruments TI-84 Plus Silver...
I can not graph simultaneous equations. Mode is set to functions and simutaneous. Megaphone(?) is to the left of y= instead of \ (or /). I can do this on other TI 84s but not my own!!
What you call a megaphone is a bit of graph style that the calculator can use to display graphs. There are 7 styles. To select a style, open the Y= editor. On the same line where you typed in an equation, use the left arrow to move the cursor on the graph style piece. Highlight and press ENTER. Each time you press ENTER, the style changes, so you can cycle through all the available ones. Be careful with the bubble style, it will not leave a graph. It will evaporate.
Whether you draw the graphs simultaneously or sequentially amounts to the same thing at the end. Both graphs will be present on the same sceen (except the bubble).
What you should make sure of is that the equal signs of both functions (Y1=, and Y2=) remain highlighted as cursor moves to another location. Usually, an equal sign becomes highlighted as soon as you start enbtering the relevant function. If you cannot keep both highlighted, I suggest you reset the calculator RAM.
To reset Ram
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER] . Press [CLEAR] to clear the "Ram Cleared" message.
If for some reason you do not want to clear the Ram, you must turn statplots of.
To turn StatPlots Off
Press [2nd] [Y=] (STATPLOT). Select [4:PoltsOff][ENTER][ENTER].
That should work.
Hope it helps.
Don't forget to rate the solution and don't be stingy: 4 thumbs up won't leave you any the poorer.
Nov 25, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus won't graph two functions at once. Only one equal sign highlights. My math teacher doesn't even know what to do and I really need two functions to show on one graph.
Turn the satistical plots OFF
Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
Clear the lists (statistical lists)
Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
Try your graphs again.
If you still have problems, just reset the RAM:
Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
Now you should be able to draw the graphs.
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Texas Instruments TI-84 Plus Calculator
I need to use the equal sign
One: just press enter/solve
Two: press 2nd Test (Math) then press enter
Mar 04, 2009 | Texas Instruments TI-84 Plus Calculator
Maths graphing
Reset the RAM and try again. To reset RAM press [2nd][MEM][7:Reset] [All RAM] [2:Reset]
Hope it helps.
Apr 04, 2008 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
122 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
