Question about GE (PSS26MSRSS) Side by Side Refrigerator
Gets to much ice. water drips from condenser coil anyway a coil by where the condenser is. The refrigerator works for awhile and then stops and will start again but only runs for a day or so then stops again
  • GE Master
  • 1,606 Answers
Sounds like a main control board problem . Unsure of your terminology though .
Posted on Jul 19, 2009
How to fix water leak n freezer
Some thing I would do if mine had a leak is secure the source of water. mine Is in the basement. it's a clear 1/4" tube with a small valve. once pressure is off I would try to isolate where it's leaking from.Usually water comes in on a high corner. My ice maker is on the left so the line comes in behind it. Tell me you have an ice maker. stop me if you don't have an ice maker... ok you do, good.
Now the supply branches off to cold water or ice maker. It gets the water cold as it passes through that area,then goes to the choice cut-out in the door. you may need to cheat the doors to watch things drip. Ask yourself is the water making the trip to the ice maker or has there always/recently been an issue. I had a weird prob last summer where the ice maker didn't work and there was water everywhere in front. Turned out the ice cubes mutated into an weird size that never let the small door shut; hot air from the room melted the weird size; next request for ice replaced the mutated size, keeping the small flap open and the vicious circle started again. Anyway that might not be your issue but (good memories) cheat the doors watch where it's dripping from. Get flashlight, it gets dark with the doors "shut" look for something to tighten. plus my big Cadillac LG came with a factory plug you could replace the filter with (is your filter installed correctly?) This plug Im talkin about seals everything off I believe, so It can be a useful tool to troubleshoot with... Good luck my polar friend~~~~SC door cheating refers to a way that the equipt thinks doors are shut so it acts normal, for troubleshooting only.
Nov 21, 2014 | Maytag Refrigerators
Water is freezing over the freezer coils and dripping onto the top shelf. We have melted the ice and cleaned it out, but the problem came back. The refridgerator is working and so is the ice maker. Is...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 21, 2011 | Kenmore 64802 Top Freezer Refrigerator
Is there a drain tube on this model? Water is all over the floor. Also, there is a cold freon line where the insulation has come off, could that be condensing water and dripping to the floor?
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 16, 2010 | Refrigerators
My whirlpool side by side suddenly stopped working, only the interior light would come on. Nothing else was working. A couple of weeks prior to this, food started freezing in the refrigerator, then...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
HOT POINT FRIDGE - FREEZER DRIPS WATER
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice buildup in freezer drip pan and water overflow when in defrost mode. water drips out the front bottom freezer door. Maytag model msd2736gr
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Maytag MSD2736GR Side by Side Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
The freezer has ice build up on vents
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
also click the links below for more help
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
