Question about Crosley CWDH11W Front Load Washer / Dryer
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops and says OE. What should I do next?
  • 3 Answers
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Posted on Aug 27, 2009
    New Friend:
My washer washes for a while than E7 pops up don't no what it means
Posted on Dec 27, 2014
Lg washER AND DRYER. What does OE mean
AN OE code means that the Front Load Washer was unable to drain water.
Jan 11, 2017 | LG Washing Machines
My washer has stopped it still has water and soap in it OE is flashing on the screen
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
It won't drain...keeps stopping and says OE
Kevin
Dec 11, 2010 | LG WM-2277HW Front Load Washer
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG WM0642H Front Load
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
Washing machine front loader has OE error code
Mine did the same and there was a 20 cent piece in the drain filter which is located at the bottom front left hand side you take off the cover - beware that a lot of water may come out - have towels ready. or your outlet pipe may be blocked. OE is a draining error message
Aug 22, 2009 | LG WM-2277HW Front Load Washer
Crosley CFW8000GR OE Problem
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WASHER/DRYER
OE is a drainage error.
This can be anything from a plugged filter screen to a faulty drain pump.
The filter screen location and cleaning procedure can be found in your owner's manual or online at the LG website.
Aug 05, 2008 | LG WD-12126RD Front Load Washer / Dryer
Crosley CWDH11W Front Load Washer / Dryer Logo
623 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
