Question about Evesham Axis 64 3200+ Choice (AXIS643200+CHMAR04) PC Desktop
My 5 year old Axis 64 Dominator (AMD 64 3500+ is getting very slow. Is it worth tackling this by a software clean-up & what would you recommend. Should I upgrade hardware, so far only RAM has been upgraded
    President:
  • 948 Answers
If it is getting very slow at booting up and doing everything it is well worth wiping the hard drive and reinstalling the operating system. Your performance should then be the same as it was when new.
If it is only slow at running the latest graphic-intensive games you should upgrade hardware. Processor, video card, and faster ram will give you the best improvements there.
Posted on Jul 18, 2009
  • 374 Answers
Tackle it with a software SmitFraudFix download it from here http://www.afterdawn.com/software/desktop_software/desktop_security/smitfraudfix.cfm
whoever programmed this software sure knows where to hit. Try this and your programs will run faster. Hardware upgradation has no limit if you can just do it.
Power light flashes but PC will not boot up following power outage
First off: Protection is important and the ONLY way to go is with a UPS (Battery backup protector). These devices allow the computer to SLOWLEY close down and protect the motherboard and hard drives. Simple bar protectors are of little to no use whatsoever. As for the Start UP; the Boot Sector on the Hard Drive has been compromised. If you attempted to start with the F8 key when you started up the computer and failed to Boot in the Safe Mode, you definitely lost the operating system.
You can try to do a Restore, but that may not be effective.
When a Computer starts, there is usually a Beep (called a Post) and one Beep indicates the motherboard is active. Several beeps indicate a mal-function of the motherboard and it was damaged. In some cases, the Memory (RAM) can be damaged from electrical surge, and thus the computer will not start and the monitor will not be active. Do not touch the internal leads as they are not the problem. In closing, a CPU is very sensitive to power surge and the CPU in some cases can be defective. All in all, with so may options or repair issues; only a professional has the equipment to search for the solution. Good luck: DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Evesham Axis 64 3000+ (AXIS643000+MAR04)...
Over clock processor
The Dell Laptop overclock is done via the BIOS - accessed during boot.
Another method to overclock is by using software, (I don't have any to recommend due to not being familiar with which is better / worse / etc).
Sep 18, 2013 | Dell LATITUDE Computers & Internet
My wife's computer is an Acer Aspire 5100 with a 4000 AMD Athlone 64 processor. It came with only 1 GB of memory and is runniing Vista Home Basic. It is terribly slow and I would like to increase the...
yes one will be for single channel ram the other for daul channel ram.if you have the acer owners manual it will tell witch ones are single and witch one is daul.
Sep 21, 2010 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
AMD ultra processor produces more heat what can I do?
Find your laptop model at this website and follow the instructions for cleaning out the CPU fan and heatsink.
Jan 30, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Computer Malfunction
3 years of such a garbage? Throw it out!
Mar 25, 2017 | Computers & Internet
COREL x4 running very slow & spooler problem
System Requirements:
Processor:
# Pentium III, 800MHz or AMD Athlon XP
Operating System:
# Windows XP with Service Pack 2 or later
# Windows Vista (32-bit or 64-bit editions)
Hard Disk:
# 430 MB
Memory:
# 512 MB RAM
Optical Drive:
# DVD-ROM
Other:
# 1,024 × 768 or better monitor resolution
# Mouse or tablet
Where these are the minimum specs I would recommend at least 1+gb memory and a good graphics card and a P4 or AMD processor running at 1.8ghz or better, and that would depend on how in depth you get into the program
Mar 10, 2008 | Computers & Internet
Evesham Axis 64 3200+ Choice (AXIS643200+CHMAR04) PC Desktop Logo
216 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
