Question about JVC Audio Players & Recorders
JVC AL-E300BK manual
I have a JVC AL-E300BK turntable, but I don't have the electricity adapter (which connects to the DC 11 plug). I found something on the internet, but I'm not sure it's the right one. Now I am looking for the partnumber, so I can know for sure.
Hello, I have the same problem as you, did you find the good adapter? Thks!
Posted on Jun 30, 2010
What power supply do I need for a JVC AL-E300BK turntable?
That label on the lower right of your photo shows the polarity connections. It looks like the (+) is on the inner connector and the (-) is on the outer or shell. You need a 12 volt power supply of at least 1 amp rating. You can buy a power supply from radio shack that will have different plugs so you can choose the one that fits. Just make sure the polarity is set correctly. If your not sure bring the turntable into radio shack and ask him for a power supply for it.
Dec 20, 2014 | JVC Audio Players & Recorders
My JVC turntable has no plug, just a 10-13v lead
Probably as long it produces DC. However you will have to adjust the speed. As the unit was set for a certain voltage which wouldn't change. It will either go fast or slow depending on what the original voltage was. The speed adjuster will either be two presets one for each speed that could be located under the turntable base (covered by a sticker) or on the power board of the deck. Or they might be on the motor itself.
Apr 26, 2014 | JVC AL A158BK Turntable
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Connection to PC
you need a stereo male 3.5 plug to female RCAS and connect the turn table to the RCA side and the 3.5 mini stereo plug into the microphone input of the PC
Aug 06, 2013 | JVC AL A158BK Turntable
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
I have a JVC AL E31BK turntable that I want to connect up to my system. I need a power adaptor for it. It says it requires 11-13volts but I don't know the amperage required. I don't want to use the wrong...
Normally these low power turntables connect to a unit audio system that supplies them with power. If you find out that you should be able to track down the specifications of it.
Jan 08, 2011 | Audio Players & Recorders
Speed switch doesn't work
hi, maybe you hve to replace the tack switch of your turntable even thougr you switch but the contactss maybe not in the connection,,
Apr 09, 2009 | JVC AL A158BK Turntable
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
752 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
