A fairly quick solution is to turn the unit OFF & unplug it for 15 - 20 minutes. Once the time has elapsed, plug the unit back in & turn the ON/OFF Switch to ON. During that time out, the electronics should have reset and reverted back to the original factory settings. You should now be able to set the controls as you like.
Very simple. Remove batteries from remote and after sometimes replace batteries and use the remote. One more method, press timer button and then press < or > till it comes to 00.00. And then press set button. Another method, press timer on and then press cancel button. Hope, helpful?
Dear friend. the timer problem is very common. Remove battery from remote and also remove power to unit. Again plug power on unit and start with remote and try to cancel the timer on and off. Press set. And also cool setting must be minimum 3 degree less than room temperature. Helpful advise?
