Question about Bunn VPR Coffee Maker
Bunn Series VPR, pour water in, water comes out cold
    President:
  • 1,273 Answers
Test that you have it plugged into an operating outlet.... Check that all of the switches are "on" (the warmer and the heater switches). If this doesn't help, you'll need to unplug the unit and test the switch and element for proper operation. Both can be tested for continuity. If they all test good, then I'd suspect the thermostat.
Good luck and best regards, --W/D--
Posted on Jul 18, 2009
We have a Bunn vpr pot and we empty it in the fall and restart it in the summer. How much water needs to be added and how long do we wait until the water is ready? Also once we made a pot do we just need...
The bunn VPR is a gravity brew system what you put in if the tank is full is what you will get out. So pour water in until it flows out the sprayhead, then turn machine on, when it heats up fill up a carafe with water (1.9Liters) and put in your filter with water and brew. It is a good idea to pour water in every morning to make sure tank is full especially if you are not using brewer on the weekends.
Jun 26, 2011 | Bunn VPR Coffee Maker
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
Sep 15, 2010 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Pour in one full caraffe of cold water when the machine is not switched and cold.the water immediately runs out. The switch on and it keeps on boiling. Should it not switch of when temp. is reached. Model...
www.bunnomatic.com/pdfs/commercial/manuals/33545.0000. From what I understand the swithc is to stay on at all times unless you are going to be away for awhile. The water you are pouring in will be the reseve for the next pot. I'm not sure if it should be boiling but check the filling instructions from above . I had no idea how to fill as mine was bought used. Good Luck! God bless!
Feb 14, 2010 | Bunn Pour-O-Matic VPR
Poured water into a Bunn Vpr coffee maker, the coffe was cold. Why did this happen?
Possible the hi-limit turned off the heater, the thermostat is not working or the elements are damaged, or the inline thermal fuse is damaged.
Nov 20, 2009 | Bunn VPR Coffee Maker
Hi! I got a new Bunn VPR last week but did not run water through it because I was waiting for our maintenance guy to install a GTRI outlet for it. When he installed the outlet on Saturday he plugged in...
It sounds as though the thermal cutout has been put to the test and it didn't pass. I would advise you to try to get the company that the repairman works for to replace the entire machine, after all it is brand new and changing parts at this venue could void the warantee.
Sep 22, 2009 | Bunn VPR Coffee Maker
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn VPR Coffee Maker Logo
203 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
