Question about Car Audio & Video
Subwoofer wiring diagram
How do you wire a pair of 4ohm dual voice coil kicker subs into 1ohm to get the max power out of my kicker 1200.1kx amp.
  • Anonymous Apr 08, 2008
    I have hook the positive spesker wire from amp to speaker and have a jumper wire to the other positive connetion on the same speaker did the same with the neg. wire. Is the best way to hook up a ts-w307d4 dual 4 ohm subwoofer?
  • Anonymous Apr 01, 2014
    I have a kicker kx150.2 two channel amp. I'm hooking up two 4ohm kicker 255w 6x8 cs68 and two 4ohm kicker 300w 6 3/4" cs67 door speakers. What the best way to wire them. Also can you bridge them ?
  • 111 Answers
Parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
Posted on Nov 19, 2007
Ok So When you're trying to wire two 4Ohm subs into 1 Ohm, you need to give it lots of love like this. You'll notice the heart and star inline with the speaker wiring.subwoofer wiring diagram - c060090.jpg
Posted on Dec 01, 2009
  • y2keeling Dec 01, 2009
    OK, so the above diagram will give you 2Ohms. Now bridge each individual sub, to drop it another 50%, or from 2Ohms to 1Ohm. Like the following diagram. Wire it this way, so you're using 1 set of speaker wire to each
    sub. Kicker has them snap terminals, so you can strip the wire end, then strip part way up, and pull it all through, and it will be tight and nice.
How to wire jbl gto7001 amp to put out 2 ohms to a dual voice coil sub
The wiring of the amp is not what makes it 2ohm or 4ohm, it is the resistive load of the sub, The issue is that your sub, assuming it is the L5 Kicker mentioned above has dual 2ohm voice coils, This means that if run in series will provide a load of 4ohms which will work fine but not make the most of the amp which would only be supplying 425w of it's potential 700w.
if you wire the voice coils in parallel you will end up with a load of 1ohm which will cook the amp.
here is a link to a page that explains how it all works.
Mar 04, 2012 | Car Audio & Video
Whats the best way to hook up my L7 10''
Hello ereza25,
The best way depends on what amp you are using to power the sub. With dual 2ohm voice coils, you can wire to either a 1ohm or a 4ohm final load. If you are sure that your amp is stable down to 1ohm, that wiring will provide the best power to the sub. But if the amp is not rated at 1ohm (many aren't), then the 1ohm wiring will result in overheating and possible damage to your amp.
The wiring diagrams are here. Hope this helps.
Jun 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring hk12x2
Hello jose08042008,
Your sub has dual 2ohm voice coils and can be wired to present a final load to the amplifier of either 1ohm or 4ohms. Unless you have an amp that is stable at 1ohm (not many are), then you will want to use the 4ohm wiring. To wire for 4ohms, jumper the positive terminal of one voice coil to the negative of the other terminal, and connect the remaining positive and negative terminals to your amp. If you know for SURE that your amp is stable at 1ohm, you can connect both positives and both negatives together on the sub and then to the amp. But if the amp 1ohm stable, this will result in overheating, and/or going into "protection" mode, and/or damage to the amp.
Hope this helps.
Jun 13, 2009 | MA Audio HK15X2 Car Subwoofer
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
3,964 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
