Question about Ruud UBHC Air Conditioner
Fan spinning no air pushed - Ruud UBHC Air Conditioner
  • James Stopp
    James Stopp May 11, 2010
    Please clarify inside or outside unit. Russ
    Problem Solver:
  • 9 Answers
Inside? you duct work is restricted or the coil is froze over. outside? your coil is completely clogged...
Posted on Jul 18, 2009
Old 30 + year old trane. Fan in front. Coils in back. Should the fan be spinning clockwise or counte? I assume it blows air out the front, pulling air pass the coils. Also have to push fan to start. Assume...
It should pull through the coil and blow out the front. The best way to find out is look at the coil. Is there dirt on the inside of the coil or the outside? If there is dirt on the inside, it tells you its been blowing through the coil. If there is dirt outside the coil it tells you its been pulling through the coil. Generally, pulling through the coil gives more square inches of air passage across the coil. Hope this helps.
Sep 13, 2011 | Heating & Cooling
My York Diamond 80 Compressor fan not spinning.
Hello, try to use a thin object to spin the fan blade, if it starts up with help pushing it the capacitor is bad and must be replaced. If the fan does not start up by pushimg it then the motor must be replaced.
Aug 29, 2011 | Heating & Cooling
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
Aug 08, 2011 | Heating & Cooling
Fan will not spin...motor is humming..fan will spin if i push it then it stops...probably just beed a start capaceter
No its not just a start capacitor what has happened is your bearings are bad. Replace the motor and the capacitor.
Jul 15, 2011 | Heating & Cooling
May i know the rotation of the two auxillary fan along the radiator to reduced the heat on it
The fans can spin in either direction based on how the fan blade is position. If you're worried about the fan facing the right direction here's how to verify it. When the fan is on it is suppose to pull the air through the radiator and pushing it out into the engine compartment. Basically the fan helps more air come into the front of the car which in return cools down the radiator. So just check which way the air is being sucked in and pushed out, the outwards air should be going in the direction towards the rear of the vehicle. If you have any more questions please let me know.
Mar 25, 2011 | 1996 Nissan Maxima
Fridge doesn't col freezer is fine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Jenn-Air JCD2295HES Side by Side...
Freezer side working fine but refrigerator side not cooling at all. Has been like this for a week or so.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area..
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
Fan is on but it is not cold could it be the compressor
The evaporator fan motor may be on but not spinning fast enough. They last 4-5 years.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Refrigerators
Exterior fan doesn't spin unless lightly pushed. Is there such a thing as a 'fan clutch' that may cause such a problem? How is this problem repaired?
If it spins up to speed with a little help from your hand or whatever, then my guess is that a fan start capacitor is faulty. It gives fan a voltage surge/spike to get it up to speed from off.
Aug 17, 2009 | Amana PTH123B25AJ Heat Pump Air...
Ruud UBHC Air Conditioner Logo
54 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
