Question about Jandy Lite2 LJ125 Ceramic Gas Heater
Pilot light is lit, burner will not come on
Pilot light is lit but the burner will not come on.
    President:
  • 1,723 Answers
The thermocouple must be in the flame of the pilot and producing a signal to the gas valve. Also check thermostat
Posted on Jul 18, 2009
3 Suggested Answers
SOURCE: Williams 3003622 Wall Mounted 30,000 BTU The pilot
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Posted on Dec 16, 2010
  • 33 Answers
SOURCE: pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
The pilot light is lit but the burners dont light up
clean out the burner...I just blew the burner with the air compresser and knocked the webs and dust out...works great now
Aug 01, 2009 | Raypak Pool & Spa
Jandy Lite2 LJ125 Ceramic Gas Heater Logo
1,016 people viewed this question
Top Jandy Heating & Cooling Experts
Craig Butler
Craig Butler
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
