Question about Dryers
Get a squeeky sound from my maytag dryer every time I use it
It seems to do this no matter how heavy the dryer load is, as soon as the drum turns, and continues until the dryer stops.
  • 441 Answers
This is a normal issue, the dryer has "Bearing Slids" that where down over time, you can order new ones from marcone.com with your model #, you will need to take the front of the dryer off to replace then
Posted on Jul 18, 2009
Maytag ensignia dryer drum not turning
The belt would be the first thing I would check sounds like it may have broke off.
Here is a link for parts and other causes. Maytag Dryer Drum Not Turning
Jul 14, 2016 | Maytag Dryers
I have a Frigidaire front load dryer that makes a very load squeeky thumping sound like there is something heavy in there tumbling... also my clothes get stuck in between the drum and frame of the dryer...
Broken wheel or wheels the drum turns on. Not to difficult to fix. Both RepairClinic.com and appliancepartspros.com have videos to show u how good luck
Mar 05, 2015 | Frigidaire Dryers
Maytag MDE9316AZW Clother Dryer won't start
Make sure that nothing has gotten caught up in the blower wheel which is located in the exhaust housing at the front section of the dryer. You can try turning by had and listen for noise, but sounds like something may be in the exhaust housing. If not it will be motor.
Feb 01, 2010 | Maytag MDE9316 Dryer
I have a squeeky maytag dryer that seems to be getting louder. Is there a lubrication that I can apply to a part?
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have is in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
When I turn on the dryer you can hear a drag and turns loudly
Sounds like you may have a sock or something stuck between the drum and the front felt seal...or maybe your drum roller needs lubrication or replacement.
If you have a front loading machine you would normally pull the front of the machine off, that will expose the drum and seal, if you remove the drum, then that will expose the rollers.
Lube the shaft of the rollers with a good grade of machine oil such as
3 in One oil.
I hope this helps
Oct 01, 2009 | Maytag Dryers
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Clunking maytag dryer
the machine is opened and inspected from the front
opening from the front there is no heavy lifting or moving of the dryer needed,
the usual causes of a ' cyclic clunk '
a worn spot on a drum felt. when that area reaches the bottom, the weight of the
drum causes a clunk.
a damaged belt that clunks when the tear hits the drum
a collapsing drum roller(replace in pairs)
each is easy to fix, cheap,
Sep 03, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer Noise
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Aug 14, 2008 | Dryers
Dryer making loud noises
You need a new drum roller in the back of drum housing.
Jun 16, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
