Question about Garden
Craftsman MRS 650 WON'T STAY RUNNING. REPLACED SPARK PLUG. WHEN YOU CAN GET IT STARTED IT WILL STAY RUNNING FOR ABOUT A MINUTE. WHAT SHOULD MY NEXT STEP BE?
  • 718 Answers
Remove carb and clean it. Then see what happens. Be careful watch how you take things apart and put them back in the same order.
Posted on Sep 26, 2009
My 5 hp craftsman tiller won't stay running changed gas sprayed carb new plug started it ran ok next day starts won't stay running dies fast like no fuel but can smell gas.
when it dies see if it will restart using a shot of starting spray in the air cleaner if it starts or sputters, sounds as if you have a plugged up carb you will need to dissasemble and soak in white vinegar for a few hours to un clogg (carefull with any gaskets)
if still nothing even with spray then you have a weak/defective coil or dammaged spark plug (start with plug replacement)
Aug 06, 2014 | Garden
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
1997 subaru Impreza sport won't stay running . stalls after minute replaced Fuel pump,filter spark plugs wires ,cleaned injectors checked fuel pressure what next
check your grounds. I find many easy fixes by cleaning all the grounds around the engine bay. I would also check the ground at the fuel pump connector that wiring is prone to corrosion and breakage
Feb 24, 2013 | 1999 Subaru Impreza
My craftsman p2 weed eater won't stay running
remove the muffler and run it if ok open the muffler and cllean the screen inside a resticted exhaust will not allow exhaust flow then the engine can't rev up
Aug 06, 2012 | Craftsman Garden
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Nov 17, 2009 | Craftsman Garden
Husquavarna 650 21 RS (650 Series push mower
May be a blockage in the carburetor. If it's a briggs motor or tecumseh motor on it, check the flywheel key. On a briggs if the key is sheared you'll have no spark at all. If it's a Tecumseh and the key is sheared, you'll probably have spark, but this throws the timing off and could possible show signs of wanting to start, but may be pulling the pull cord handle out of your hand when it tries to catch. Be very careful of this. Tecumseh will give you a spark but if the key is sheared then it'll be the timing. Also, check the brake band on the flywheel and make sure the ground wire isn't off or shorted. Good luck.
Oct 08, 2009 | Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Garden Logo
518 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
