Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Reset inteliflow pump to factory defaults - Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
  • 128 Answers
Hold down the 1234 together for 5 seconds
Posted on Aug 23, 2009
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
The motor will not come on everyday like it is suppose to. You can cut the breaker off and turn in on again and hit start and it will work fine until the next day. Control panel was replaced about six...
To protect the IntelliFlo pump electronics from damage due to freezing conditions, the pump will switch itself on to generate internal heat when the air temperature drops below 40° F. This feature is not intended to protect the system plumbing from freezing. The pump will run at a lower speed than what you have it set, unless you have programmed the adjustment.
The Intelliflow pumps are great pumps, but come at a disadvantage- A whole lot of electronics.; Since the intelliflow pumps are fairly newer in the market, and you have already had the electronics replaced recently, so I am going to presume that you still are under Pentair Manufacturer warranty.
The issue you are describing remains a problem with the electronics. Since you are not getting any alarm codes, there may be in issue in the wiring or you may have a defective pump. Before calling into the manufacture, lets reset the pump to factory defaults:
The IntelliFlo VS-3050 pump can be reset to the factory default settings. All previously adjusted pump speeds that were saved will be erased. To reset the pump to the factory default settings: 1. Ensure that the pump is powered on and the green power LED is on. 2. Press the Stop button to stop the pump. 3. Press and hold all of the four Speed buttons simultaneously for four seconds. Power off the drive and reenergize. The default settings will be in effect.
If this solves your issues, then you can program the pump to operate at the desired time/speeds.
If you are still having issues, I recommend contacting Pentair Warranty at 800-831-7133. Be sure to have the date of install, the Serial and Model numbers handy when you call.
Dec 08, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I am looking for the Security Key
Unfortunatly there is no way of accessing the router security key if you have forgotten it however you can reset your router to factory default here is how
" The Reset button is located on the right side of the product label. There are two ways to reset the Router to its factory defaults. Either press and hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen in the Router's browser-based utility The Reset button is located on the rightside of the product label. There are two ways toreset the Router to its factory defaults. Either pressand hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen inthe Router's browser-based utility" was this helpful?
Oct 05, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Locked out of pool pump control.
should be either hold 1234 down and enter at same time for 7 seconds if doesn't work hold down 1 and enter
Jun 14, 2009 | Pentair Intelliflo Variable Speed...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
289 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
