SOURCE: cd player seems to be jammed
Well if the cd player has a reset button push it and it might kick the cd out on it's own. But if it dont then try by removing the battery cable for 1 minute. When you power most electronics they go through a self diagnostic and might just eject the cd. If that dont work then there is only two other things you can do. 1 is to take a small pair of needle nosed pliers and CAREFULLY remove the cd. But this also takes the chance that you might hit something vital and trash the cd player! 2. Uninstall the cd player and remove the top And carefully push the cd out the same way it was put in. If you do get the cd out of the player then the first thing you should do is to put in a laser eye cleaning cd and clean the player. Then see if it comes out by itself. If it does not then it is time to buy a new cd player. KENWOOD cd players are one of the few that come with a reset button that will reset the deck and remove the cd automaticly. This is a very nice option. Good luck
SOURCE: Car stereo wont accept disk (motor doesnt pull it in)
you are correct it is not "seeing" the disk with it's infared sensor to repair this sensor you must disassemble the radio
SOURCE: cd error wont play or eject 3 of the cds in the 6
sorry unit is not servicable you can get a used one at many junkyards
SOURCE: ba falcon heater
Just had the same thing happen to my BA. No hot air. I'm a bit of a handyman so I had a go myself. 8 Hours is a reasonable estimate. You have to remove the steering column and entire dashboard to get the bugger out. Not a job I would attempt again.
SOURCE: BA Falcon 'door open' light is on, can't lock
Hi I have the same problem on my BA XT Falcon
Strangely it only happens after it's rained on my car (usually overnight) I then notice that the drivers lock is up and will not lock again until a nice sunny day comes and I leave all doors wide open for hours and hours!! Then all of a sudden once closing all doors normally the little dash door light turns off, and I can again lock the doors
Since it rained all last night here, guess what? It happened again!
So I've checked everywhere and cleaned and you name it, but nothing, I'm positive that when a warm sunny day comes again though, all will be ok.
Most annoying issue ever.
Where is this tiny bit of water that's causing this?
And which door?? Can I just disconnect one door at a time? I don't know it's driving me crazy!!!!
