Question about Kenmore 62802 Electric Dryer
Kenmore dryer will not run! If i put the dryer to a run potion the heater turns on without hitting the start button. the heater will even turn on with the door open
  • 12 more comments
  • bobnib Jul 18, 2009
    I removed and cleaned the heater and replaced. I also checked to see if there was a short to the can and also the dryer. there is no short....
    btw.. this is a kenmore 90series 110.69912990
    kenmore dryer will not run! If i put the dryer to a run potion the heater turns on without hitting the start button. the heater will even turn on with the door open. I removed and cleaned the heater and replaced. I also checked to see if there was a short to the can and also the dryer. there is no short....
    No.
    but the heater turns on when i put the timer to any run option.
    even with the door open
  • bobnib Jul 19, 2009
    I verified the timer and it is work properly, just to be safe i cleaned the contacts. I removed the motor and this is what i found. see attached photos
    http://i293.photobucket.com/albums/mm75/...
    Also here is a little back story that may help. The problem started when somthing started burning in the dryer. Everything was working at this point! heater was running and the motor was running and tumbler was tumbling. I quickly stopped the dryer to air out my house. About 30 min later i tried to restart the dryer and thats is where i am today.
    Jul 18, 2009 - kenmore dryer will not run! If i put the dryer to a run potion the heater turns on without hitting the start button. the heater will even turn on with the door open. I removed and cleaned the heater and replaced. I also checked to see if there was a short to the can and also the dryer. there is no short....
    Jul 18, 2009 - No.
    Jul 19, 2009 - I verified the timer and it is work properly, just to be safe i cleaned the contacts. I removed the motor and this is what I found. see attached photos http://i293.photobucket.com/albums/mm75/... http://i293.photobucket.com/albums/mm75/...
    the problem I have is not the heater shorting to the canister. I am adding photos to prove this. http://s293.photobucket.com/albums/mm75/... http://s293.photobucket.com/albums/mm75/... http://s293.photobucket.com/albums/mm75/... http://s293.photobucket.com/albums/mm75/...
    I also check the coil out of the can http://i293.photobucket.com/albums/mm75/... http://i293.photobucket.com/albums/mm75/... http://i293.photobucket.com/albums/mm75/...
    I checked this and it works also
    should the elements be normaly open or closed?
  • bobnib Jul 20, 2009
    Could this problem have somthing to do with the motor? http://i293.photobucket.com/albums/mm75/... http://i293.photobucket.com/albums/mm75/... http://i293.photobucket.com/albums/mm75/...
    how do i check the motor centrifugal operation?
    can anyone explain how the motor centrifugal works?
  • Kenmore Master
  • 3,361 Answers
Your motor switch has shorted out, There is a centrifugal switch on the motor that is in the ON position even though the motor is not running. Remove ONE "large" wire from the motor switch. Probably RED and probably one of 2 on the outside positions of the motor switch. If the heater does not work with a wire removed, replace the motor,because the motor start switch is not available as a separate part.
Posted on Jul 20, 2009
    President:
  • 1,714 Answers
Okay, here it is. This is the circuit you have to check> The operating therm. could be stuck on, The motor has a set of contacts in the hater too. You need to check and make sure they aren't 'welded'. You've changed the timer so I'll assume that's okay. Can you read the schematic? Make sure there aren't any other thermostats that control the element. I'll help you figure it out, let me know
Posted on Jul 19, 2009
  • Craig Butler
    Craig Butler Jul 20, 2009
    It really seems like the motor centrifugal would be the cause here....
    Top Expert:
  • Kenmore Master
  • 76,848 Answers
Your photo's are to small to see what you are doing, i suspect the heating element cotrol circuit is shorted replace it.
  • 3,741 Answers
This same problem happens when -- Check for a stuck/welded closed start switch with an ohm meter. Should be open ( no continuity ) when not pushed and closed ( has continuity ) when pushed.
the cost is $10
and here is where you get this
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2825&PPStack=1
click the link directly.also check out for open circuit near the start switch.its actually not able to give command to heater to start or stop.so it just runs when not required.
also check out the thermister.to know how to check thermister click this link
http://www.applianceaid.com/evenheat.html
Please do rate the solution. Thank you for using fixya.keep updated. thanks
    President:
  • 744 Answers
Hello, your problem is with the heater, Over 20 years I have seen this problem many times. Unplug dryer and remove the back panel, Then loctate the heater bottom right. You will have to pull off the wires to the high limit and heater. You will also have to remove a screw from the bracket at the top so you will be able to remove the tube that holds the heater. Once you have done this there are going to be 2 screws either side of the heater remove those and now remove the heater. What has basically happend is the coil has broken and one side of the break has touchesd down to the chassis of the heater case (grounded) once you set the timer the rest of the control panel has been bypassed and the heater turns on. Examine the heater coils for damage to check this diagnosis. If you don't see damage it does not mean there is no damage. Test the heater coil for condinuity from terminal 1 to terminal 2 if you have condinuity test terminal 1 against the chassis of the heater for condinuity then test the other terminal against the chassis....one of the will show condinuity and prove this diagnosis...replace the heater. Good Luck!! please feel free to comment again if you have any other questions or concerns. Mike
  • 6,784 Answers
HI, i have one question to ask before i render my solution. When you select a cycle on the timer and, hit the start button, dose the drum turn at all??
Posted on Jul 18, 2009
  • Michael Masters
    Michael Masters Jul 18, 2009
    Ok, this will confirm a major defect in the timer module. the timer is responsible for initiating the element functions and main start up functions as well. it is the principal initiator in this situation. This type of defect can be caused by power surges or a electronic pulse for the outside pole transformers. this can happen at night when you are sleep with no warning. The timer module circuit can become damaged or, welded in this case, creating a closed circuit within the circuit layout. this can also affect the start button and, door switch as well.
    I recommend testing the door switch and start button for proper Resistance levels and continuity. if both switches are ok, replace the timer.
  • 3,037 Answers
It sounds like your heating element is grounded to the canister or the bracket. Unplug this dryer till this is resolved as you have 240 volts feeding to the case if this is the problem. You need to remove the outer panel to get to the heating element to check this. Let me know how this turns out and what you find.
Benjamin
Kenmore dryer wont spin
check door switch
Sep 01, 2014 | Kenmore Dryers
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
When I hit dryer start button nothing happens
heatman101
Dec 27, 2010 | Kenmore Dryers
With the power on, once I hit the "start" button
heatman101
Nov 07, 2010 | Kenmore 97566 Electric Dryer
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
My Kenmore 500 series electric dryer seems to be heating, but just stopped running. I hit the start button, and the drum heated up, but did not start turning. I'm guessing that the start switch is not...
heatman101
Oct 14, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Dryer starts in timed position without hitting start button
REMOVE THE TOP BACK PANEL,TURN THE SWITCH CLOCK WISE AND PULL OUT,REMOVE WIRES,GO TO SEARS .COM CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND GET YOUR PART-MIKE
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore 62802 Electric Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
