Carburetor/fuel issues
SOURCE: Need diagram for this carburetor #632508 or 632508
below is a copy of the only diagram I could find for you. hope it helps! thanks.
SOURCE: need to see the carburetor diagram for a 2000- wont start
I could not locate a diagram of your machine's carburetor. I can tell you, for certain, that the carb does have a rubber drain tube that goes from the bottom of the float bowl and vents to atmosphere beneath the vehicle.
There are three required ingredients required for combustion: fuel, compression, and a spark (at the right time). Try to find out which of these are missing. Loosen the drain screw on the float bowl. Is fuel present? Check the compression - you've got to see at least 140 psi for anything to happen. Pull the spark plug and crank the engine. Is there a spark?
If it has sat for an extended period of time (more than just a couple of months) then the carburetor will be plugged with fuel varnish. It is very easy to think you've got everything cleaned, when the jets are still plugged up. I would take the carb apart and remove the jets. Hold them up to a light source and look through each one. If you can't see through them, there's the problem.
SOURCE: Hyundai Accent 1.3 litres carburetor
ive got a 1994 1.3 accent and now its spluttering was does it mean ?
SOURCE: carburetor diagram
Honda Rider Club membership provides a generic service manual for members. For a small fee, you can join and get access to the manual for your model according to info at the site. http://hrca.honda.com/
